Thread: Reprogram key fob
Results 1 to 20 of 23
  1. #1 Reprogram key fob
    Jul 2013
    sweden
    Is here anyone how can help me. I need to repogram my key fob too my grand prix-90. I cant find how too do that. Pleas help me.
  2. #2 Re: Reprogram key fob
    Aug 2011
    'Merica
    Google is your friend
  3. #3 Re: Reprogram key fob
    GTX Level Member Bills1997GTP's Avatar
    Oct 2012
    Philadelphia
    You mean 1990 Grand Prix ?
  4. #4 Re: Reprogram key fob
    Jul 2013
    sweden
    yes i do, cant find anything on google
  5. #5 Re: Reprogram key fob
    Aug 2011
    'Merica
    Try this:
    Locate the black-and-white programming connector wire located in the right-hand side of the trunk. Pull back the trunk's lining to access it. On the end, you will find a terminal in a plastic connector. Place this against a bolt or the trunk latch. You will hear the locks cycle. Press any button on the remote, and listen for the locks to cycle again. Repeat this step for all remotes
  6. #6 Re: Reprogram key fob
    Aug 2011
    'Merica
    These instructions were how I got mine to program (03 GP GT):
    Enter the car and close all doors. In the fuse panel, remove the "MALL PGM" fuse. Put your key into the ignition, and turn to "ACC." Turn the key on and off within a second. Open and close the driver's door and listen for the chime that indicates you are in programming mode. Press and hold the LOCK and UNLOCK buttons for 14 seconds, listening for the chime. Wait 14 seconds for the second chime. Repeat this step for all additional remotes, remove the key, replace the fuse, and exit the car. You will have programmed the remotes.
  7. #7 Re: Reprogram key fob
    Jul 2013
    sweden
    okej, i have fund it but nothing happens then i do that, can something els be wrong
  8. #8 Re: Reprogram key fob
    Aug 2011
    'Merica
    no clue....battery dead in key fob?
    Did the car come with a for or did you buy one for it?
  9. #9 Re: Reprogram key fob
    Jul 2013
    sweden
    it is new batteri in the fob, it come with the car
  10. #10 Re: Reprogram key fob
    Aug 2011
    'Merica
    try the second set of instructions if the first ones didn't work
  11. #11 Re: Reprogram key fob
    Jul 2013
    sweden
    i cant find the mall pgm fuse on the car
  12. #12 Re: Reprogram key fob
    Aug 2011
    'Merica
    prob doesn't have one since it is OBD1 car
  13. #13 Re: Reprogram key fob
    Aug 2011
    'Merica
    Someone will possibly chime in eventually
  14. #14 Re: Reprogram key fob
    Aug 2011
    'Merica
    These instructions are for 1994. That is the oldest I can find.
    1. Locate the programming connector wire located in the RH trunk area.
    You may have to pull back right side trunk trim on trunk wall to locate
    the single black/white wire.
    2. The programming connector wire should have one termial in the plastic
    connector on end of black/white wire. Ground the terminal in the connector
    to a nearby bolt or trunk latch.
    Leave connector wire connected to ground through out procedure.
    3. System will now lock and unlock doors automatically to indicate
    programming mode has been activated.
    4. Press any button on keyless remote. System will respond by locking
    and unlocking doors one time to indicate successful programming.
    5. Repeat step 4 for to program any additonal keyless remotes including
    and existing keyless remotes. Do not remove ground wire between
    programming of keyless remotes.
    6. Disconnect programming connector wire from ground to exit programming
    mode.
    7. Test keyless remote(s).
  15. #15 Re: Reprogram key fob
    Jul 2013
    sweden
    thanks for the help
  16. #16 Re: Reprogram key fob
    Aug 2011
    'Merica
    Did those work?
  17. #17 Re: Reprogram key fob
    Jul 2013
    sweden
    no they dident
  18. #18 Re: Reprogram key fob
    Aug 2011
    'Merica
    you may have to call the dealer then
  19. #19 Re: Reprogram key fob
    do a google search for your owners manual, i bet the info's in there.
  20. #20 Re: Reprogram key fob
    Jul 2013
    sweden
    okej thanks
  1. Reprogram ECU?
    By GPGTdude12 in forum General Tech Discussion
    Last Post: 05-27-2011, 04:08 PM
  2. Enough mods for a PCM reprogram?
    By mousemonster1232 in forum General Tech Discussion
    Last Post: 01-27-2011, 11:42 PM
  3. pcm reprogram
    By bballa0740 in forum PCM Tuning
    Last Post: 08-28-2009, 08:14 PM
  4. $$$ How much reprogram the DIC?
    By corvetteii in forum General Tech Discussion
    Last Post: 02-16-2009, 08:56 PM
  5. PCM reprogram
    By sickofsoyo in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-04-2009, 01:35 AM
