Thread: Pioneer head unit
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 62
  1. #1 Pioneer head unit
    Apr 2013
    Michigan
    I have an 06 Grand Prix GXP. Just bought a Pioneer AVH-X5500BHS head unit. Thinking it would be simple to install like in my old truck, I take the factory radio out and wow there are a ton of wires. I have no clue where to even start with this. If someone could help me I'd really appreciate it. Thanks.
  2. #2 Re: Pioneer head unit
    I live here. DirtDog's Avatar
    Jun 2012
    Go online and u need a wiring harness for it...costs about 100 new
  3. #3 Re: Pioneer head unit
    you can buy a pig tail that plugs into the factory plug, the wire from it are labeled, so theres no guess work.
    and you'll need one of them adapters to make the door dings and steering wheel controls still work. most loose the clock too iirc when they do a aftermarket HU.
  4. #4 Re: Pioneer head unit
    Apr 2013
    Michigan
    Is it possible to send me a link to the wiring harness I'll need?? I was looking earlier and couldn't seem to find. Thanks guys!
  5. #5 Re: Pioneer head unit
    Yup it's not exactly simple. Your going to lose the calender feature on the DIC but who needs that anyways. Your going to need to correct module to retain the door chimes, onstar etc as well as one if you want to keep your steering wheel controls. It gets pricey.
    04 Comp G.
  6. #6 Re: Pioneer head unit
    Do you have the stock Monsoon system and/or onstar?
    04 Comp G.
  7. #7 Re: Pioneer head unit
    Apr 2013
    Michigan
    I have the Monsoon system and Onstar. I bought an adapter to keep the steering wheel controls but still don't even understand how to hook that up. I was thinking just speaker wires to connect but nope, bunch more wires.
  8. #8 Re: Pioneer head unit
    ahhh, moonson. you gonna want to just flat out run new speaker wires to the speakers. the new HU wont like the factory wires to the speakers.
  9. #9 Re: Pioneer head unit
    Let me see if I can find you the right harness if not I know I believe spazz on here deals with a lot of installs and can probably chime in.
    04 Comp G.
  10. #10 Re: Pioneer head unit
    Apr 2013
    Michigan
    Haha oh great that's not good. Alright thanks man! I really didn't know how much stuff I'd have to buy just to put in an after market head unit.
  11. #11 Re: Pioneer head unit
    Quote Originally Posted by DrBass93 View Post
    It's never that simple w/ modern day cars now. Hell I have had my steering wheel module installed for 4 years and have yet to bother programming it. I tried the first day and gave up
    Here's the harness wiring
    Radio 12v orange + radio harness
    Radio Ground black/white - radio harness
    Radio Ignition (Class 2 Serial Data)
    Radio Illumination gray (dimmer) + radio harness
    Factory Amp Turn-on same as power antenna wire
    Power Antenna purple + radio harness
    LF Speaker +/- tan - gray +,- radio harness or amplifier
    Notes: The amplifier is under the rear deck.
    RF Speaker +/- lt. green - dk. green +,- radio harness or amplifier
    LR Speaker +/- brown - yellow +,- radio harness or amplifier
    RR Speaker +/- dk. blue - lt. blue +,- radio harness or amplifier
    04 Comp G.
  12. #12 Re: Pioneer head unit
    Trust me neither did I. What went from a simple...I want subs and still want to keep everything stock...went to completely gutting all the monsoon crap and running 2 amps, aftermarket speakers, aftermarket headunit. It became way more expensive then I thought it would be.
    04 Comp G.
  13. #13 Re: Pioneer head unit
    Which module did you buy for the steering wheel controls?
    04 Comp G.
  14. #14 Re: Pioneer head unit
    Apr 2013
    Michigan
    Thanks! Yes I wanted a nice headunit and I mainly want it for my subwoofer. The steering wheel control is the Axxess ASWC. I saw a video on YouTube of a guy using the same one and the same headunit I bought. He was also putting it in a Grand Prix haha.
  15. #15 Re: Pioneer head unit
    It may point out how crappy the stock speakers are...lol at least that's what happened to me. Don't want to scare you but figured ill let you know.
    http://contentdocs.installernet.com/...icle/12426.pdf
    04 Comp G.
  16. #16 Re: Pioneer head unit
    Apr 2013
    Michigan
    Well I replaced the 6.5"s about a week after I got the car with some Rockford Fosgate speakers. Planning on replacing the rear speakers some time haha. Just wondering if there is an adapter that would be able to just hook into the factory plug ins and hook to this radio or if I'm going to be messing with wires??
  17. #17 Re: Pioneer head unit
    To make it easy on yourself as well as probably sound a lot better. I would just unhook the the Monsoon amp and run new speaker wires from each speaker to the headunit. Probably easier to do it now since your replacing the headunit anyways. that way the new speakers will run off the pioneer headunit instead of the factory crap and sound way better.
    04 Comp G.
  18. #18 Re: Pioneer head unit
    hey! thats what i said. lol
    everyone who does this has some sound issue using the factory speaker wires. the speakers should be changed too, something about using different power levels or some crap that i dont understand fully.
  19. #19 Re: Pioneer head unit
    Apr 2013
    Michigan
    It would probably get rid of a few wires taking that amp out wouldn't it?? I just don't understand what all these wires are for lol. I know there's Onstar and what not but dang there's just too many wires for me to understand it.
  20. #20 Re: Pioneer head unit
    i would leave all the wires that are unused there, so if some day you want to put it back to stock you can.
  1. Just put my new head unit in..
    By FriboRage in forum Audio, Security & Visual Electronics
    Last Post: 10-11-2012, 04:37 PM
  2. Which head unit is better for me??
    By copgtp in forum Audio, Security & Visual Electronics
    Last Post: 06-07-2012, 06:43 PM
  3. input on this Pioneer head unit?
    By 2dee11 in forum Audio, Security & Visual Electronics
    Last Post: 02-27-2012, 04:15 PM
  4. pioneer head unit
    By nemesis in forum Audio, Security & Visual Electronics
    Last Post: 04-02-2008, 12:59 PM
  5. another pioneer head unit question
    Last Post: 03-22-2008, 07:06 PM
