Thread: Upgrading stock system; first attempt.
Results 1 to 6 of 6
  1. #1 Upgrading stock system; first attempt.
    Jun 2013
    United States
    So I am new at this audio update thing and I have a question for you seasoned vets out there. I am putting ALPINE SPR-69 6X9 in the rear and Alpine SPR-60C 6.5" up front. These will be fed by a Alpine PDX-F4 amp from a Pioneer AVHX8500BHS HU. Will be running stinger 4gu amp wiring kit to power the amp.
    The question is "Should my stock alternator be able to handle the draw from adding this setup or do I need an upgrade?"
    Let me know if I'm missing anything important as well. Plan on running new wiring; 16gu Monster car speaker wire. Ground loop isolator? Also should note I have no intention of adding subs if that helps with the power draw question.
  2. #2 Re: Upgrading stock system; first attempt.
    GT Level Member Cocor's Avatar
    Aug 2012
    Collinsville, il
    That amp is pretty small. There won't be any alternator issues. Even with factory wiring under the hood.
    2005 GP GXP Ivory White, OBX Headers, Cat and Muffler delete, HP Self Tuned, De-badged/Custom LS4 badges, K&N CAI, Intense Poly upper mounts, Strut Tower Braces, HSRK, HID 8000k headlights, Switchback LED front turn signals, interior LED's. Dyno'd @ 275whp/275wtq
  3. #3 Re: Upgrading stock system; first attempt.
    The stock alternator will work fine as long as its in good working condition.
    04 Comp G.
  4. #4 Re: Upgrading stock system; first attempt.
    Jul 2012
    Chicago
    I have a 700 watt RMS amp in my car. Pound it on the daily. Car doesn't care. Even at night with AC and headlights and fog lights. That being said, I'm not sure if the GPs have the same alternator as the Bonne does. Even so, you should be fine.
    -Carl
  5. #5 Re: Upgrading stock system; first attempt.
    Jun 2013
    United States
    Thanks for the feedback
  6. #6 Re: Upgrading stock system; first attempt.
    Sounds a lot like what I have. I have no issues, at most upgrade the alt to a JY Bonneville or Park Avenue one that looks the same. They'll be 125amp instead of the stock 105 amp.
  1. Upgrading my audio system.. Couple Questions
    By bingen in forum Audio, Security & Visual Electronics
    Last Post: 06-30-2012, 12:10 PM
  2. Upgrading Speaker System?
    By michaelearth in forum Audio, Security & Visual Electronics
    Last Post: 12-04-2011, 01:33 PM
  3. Upgrading Stock System on a Very Tight Budget
    By SlyBlackDragon in forum Audio, Security & Visual Electronics
    Last Post: 08-29-2011, 09:59 AM
  4. Stock Security System
    By Meg99GTP in forum Audio, Security & Visual Electronics
    Last Post: 07-02-2009, 10:06 AM
  5. advice on upgrading a stock '98 gt
    By mhoran89 in forum Introductions/Noob Questions
    Last Post: 06-05-2009, 04:56 PM
