Thread: Turning signal relay?
Results 1 to 19 of 19
  1. #1 Turning signal relay?
    Jun 2011
    OK guys i need help.
    Yesterday i installed some sequential LED turn signals for my side mirror.
    When i tested them on a constant 12v source they worked fine, like this:
    ...but when i hooked them up like your supposed to, to the respective side turning signal wire.
    The fist set of led only work. The OEM turning signal relay/flasher is making them do this.
    The OEM turning signal flashes too fast and doesn't allow for my new sequential leds to work properly.
    Do you guys have any ideas on how to fix this?
  2. #2 Re: Turning signal relay?
    GTP Level Member simbah's Avatar
    Lala land
    Your car does not have a turn signal relay. the blinking of the turn signals is controlled by the BCM, so what is happening is probably hyperflash, like you would get with LED turn signals. With that being said if you install the magic resistor, like with LEDs then your hyperflash should cease to exist.
    'When someone shares something of value with you and you benefit from it, you have a moral obligation to share it with others
  3. #3 Re: Turning signal relay?
    Jun 2011
    I don't think its hyperflash, but i will look into that.
    I'm thinking that my OEM blinker wire doesn't send constant juice therefore my sequentials reset and get stuck on the first row of LEDs.
    IM adding the LEDs not replacing OEM bulbs.
  4. #4 Re: Turning signal relay?
    Donating Users Paul J McCain's Avatar
    St. Louis, MO
    Quote Originally Posted by simbah View Post
    He is correct, the car's turn signals are controlled by the BCM. Unfortunately, the only way to fix this issue is to splice in load resistors.
    I happen to know where you can find a good deal on some
    Nick C.
    Click For All Pontiac Lighting
    Your Experts in Pontiac Lighting
    (314) 205-3033
  5. #5 Re: Turning signal relay?
    I live here. DirtDog's Avatar
    Jun 2012
    Quote Originally Posted by Paul J McCain View Post
    Nick C.
    I wonder where.....cause I have no ideal :beer:
  6. #6 Re: Turning signal relay?
    Jun 2012
    But to be honest I don't think they'll work....there isn't a constant 12volt source to the turn signals when using them...its an on off power supply
  7. #7 Re: Turning signal relay?
    Jun 2011
    hmmmm
  8. #8 Re: Turning signal relay?
    St. Louis, MO
    (314) 205-3033
  9. #9 Re: Turning signal relay?
    Jun 2012
    U have a PM btw
  10. #10 Re: Turning signal relay?
    GT Level Member douger's Avatar
    Aug 2012
    Fort Wayne
    Quote Originally Posted by marines542 View Post
    The "flasher" in 2004 and above Grand Prix is indeed in the BCM, and the noise is generated within the instrument cluster.
    Each incandescent bulb has 21 watts of resistance. "Flashers" need that resistance to control the speed of the flash, and when the resistance isn't there, the remaining bulbs will "hyperflash." This tells the driver that one of the bulbs is burnt out. It's a design feature of the system.
    On older cars with the old 552 flashers, you can get a "LED" version that ignores the missing resistance. With the modern flasher integrated in the BCM and cluster, you're forced to use those ugly resistors others are telling you to use. You'll need one at each LED location.
    These things are beefy resistors...as resistors go. If my math is right...and that's no sure thing...21 watts at 12 volts gives about a amp plus draw. Even at 50 watts, those suckers are gonna get hot. They will melt plastic. The standard recommendation is to mount them against metal and away from plastic.
    It's amazing how much current a tungsten filament will carry.
  11. #11 Re: Turning signal relay?
    Jun 2011
    ... but what gets me is that im not removing the stock bulbs, im keeping them.
    Would adding the LEDs cause hyperflash even if the OEM bulbs are there?
    What about my HIDs.. would they cause hyperflash.. i removed my stock bulbs there.
    Thanks for your help guys.
  12. #12 Re: Turning signal relay?
    Jun 2012
    Ur not getting hyper flash!!! The turn signals are not a. Constant power supply
  13. #13 Re: Turning signal relay?
    Jun 2011
    Thats what i thought...
    Maybe i can catch the wires before they hit the BCM.
  14. #14 Re: Turning signal relay?
    St. Louis, MO
    Quote Originally Posted by E IN v Y View Post
    PM me if you need more advice, but as a rule of thumb if you add LEDs for the turn signals you will 100% need load resistors otherwise you'll get hyperblink
    -Nick C.
    (314) 205-3033
  15. #15 Re: Turning signal relay?
    Jun 2012
    -Nick C.
    He's adding LEDs and also keeping the stock bulbs in the fronts
  16. #16 Re: Turning signal relay?
    St. Louis, MO
    I would recommend adding resistors to the back turn signals and call it a day
    -Nick C.
    (314) 205-3033
  17. #17 Re: Turning signal relay?
    Modded for Maximum Slow burgundybullet's Avatar
    Menomonie, Wisconsin
    Because you are not using the constant power it doesnt have time to cycle in the time it blinks. I considered those for my mirror project but got to thinking that the blinking signal would be a problem. My only guess is that you have to find the wire from the signal stick before it gets to the relay I believe (Think its a relay that makes the signal blink). Once you find that constant wire you will need to run your power from that and then find a constant ground would be my best guess.
    Does this make sense?
    1978 Oldmobile Cutlass Cruiser (crushed)
    2000 Grand Prix GT (Revived DD)
    2001 Grand Prix GTP Special Edition (Weekend Warrior)
  18. #18 Re: Turning signal relay?
    St. Louis, MO
    Quote Originally Posted by burgundybullet View Post
    You are correct, in order for the sequential to function properly it will require a power source that gives it enough time to cycle.
    -Nick C.
    (314) 205-3033
  19. #19 Re: Turning signal relay?
    Jun 2011
    Makes perfect sense. Ill have to tear into my dash this weekend.
    Paul got me thinking... do i need resisters if i have rear LED tails?
    lol but thanks guys ill figure something out and let you guys know how it went... for future reference.l
  1. 06 GP Base signal conversion to Fog/signal
    By kmkecho in forum General Tech Discussion
    Last Post: 08-19-2012, 11:51 PM
  2. Where is rear defogger relay wire? (and trunk relay wire)
    By kind153 in forum Audio, Security & Visual Electronics
    Last Post: 11-02-2011, 03:10 PM
  3. Right signal light flashes fast, left signal flashes normal speed?
    By nboylie in forum General Tech Discussion
    Last Post: 11-23-2009, 06:38 PM
  4. Turning Signal
    By bct717 in forum Visual/Body Modifications
    Last Post: 03-25-2009, 03:07 PM
