Thread: Headunit install 06 GXP
Results 1 to 5 of 5
  1. #1 Headunit install 06 GXP
    May 2013
    CapeCoral, fl
    Im planning on installing a new headunit into my GXP. I have the monsoon system, Ive done some research and I know ill loose the date & day function in the DIC which im fine with. I just want to double check and make sure this is the only harness I need to complete the install of my headunit. Thanks for the input. I did search and found info but everything is scattered and just want to double check. Also in the description part from the seller it says "These harnesses will not work with Premium Amplified Systems, or bose systems" does this included the monsoon. If this isnt the right harness can someone post a link to the correct one please. Thanks again.
    New ADGM1 GM 4004 Car Radio Factory Wiring Harness Antenna Adapter | eBay
  2. #2 Re: Headunit install 06 GXP
    May 2013
    CapeCoral, fl
    Im also reading this about loosing the chimes, will the warning still display in the DIC?
  3. #3 Re: Headunit install 06 GXP
    GTP Level Member simbah's Avatar
    Lala land
    The harness you have noted will not work with the Monsoon system, as it has an amplifier that is separate from the Head unit. The harness you are looking for is the GMOS-04
    Amazon.com: Axxess GMOS-04 Class II OnStarĀ® Interface for Amplified Systems: Car Electronics
    this will retain all the chimes for your vehicle, and work with the external Monsoon amp.
    'When someone shares something of value with you and you benefit from it, you have a moral obligation to share it with others
  4. #4 Re: Headunit install 06 GXP
    I live here. DirtDog's Avatar
    Jun 2012
    I can't remember which harness it is but there is one that retains all factory chimes and xm and OnStar. It also doesn't cause the date and time to be lost. I had it in my older gp I used to have.
  5. #5 Re: Headunit install 06 GXP
    May 2013
    CapeCoral, fl
    Quote Originally Posted by simbah View Post
    thanks for the response, thats exactly what I was looking for.
  1. Headunit
    By EJRJR91 in forum Audio, Security & Visual Electronics
    Last Post: 03-29-2011, 09:41 PM
  2. Well had to get a new headunit what do you think?
    By JoshsGTP in forum Audio, Security & Visual Electronics
    Last Post: 11-07-2010, 05:51 PM
  3. Headunit Help
    By jack08 in forum Audio, Security & Visual Electronics
    Last Post: 02-28-2009, 07:00 PM
  4. Aftermarket headunit install on BOSE system??
    By FoSHO99 in forum Audio, Security & Visual Electronics
    Last Post: 01-05-2008, 03:51 AM
