Thread: Where to ground amp?
Results 1 to 11 of 11
  1. #1 Where to ground amp?
    Mar 2013
    High Point, NC
    I just bought a 400 watt amp for my 04 Grand Prix GT, and I was wondering if anyone out there knows of a good spot in the trunk to ground it. My amp is closer to the rear seats, and i only have about 2.5 feet of wire
  2. #2 Re: Where to ground amp?
    GTX Level Member Bakerdd's Avatar
    Raleigh, NC
    I grounded mine to one of the rear strut bolts
  3. #3 Re: Where to ground amp?
    Pennsylvania
    Use a self-tapping screw and bolt it down under the back seat if you like.
  4. #4 Re: Where to ground amp?
    I live here. DirtDog's Avatar
    Jun 2012
    Quote Originally Posted by Bakerdd View Post
    Bingo
  5. #5 Re: Where to ground amp?
    I'm not an audio guy, for some reason the strut bolt doesn't sit well with me as a good ground. My thought on that is.. struts aren't 100% weatherproof, the bolts corrode, the area inside the car is known to rust and that's not a good long term ground.
    I went to one of the main achors for the back seat. It's interior, clean and always dry there. Plus is was super close to my amp.
  6. #6 Re: Where to ground amp?
    May 2013
    wilmington, nc
    the strut tower is a fairly structural point, which makes it a good spot.
    My 05 has 95k w/ 75k spent on michigans salt roads and the last 20k spent in salt air on the beach. No corosion left.
    Sand down your grounding point, bolt it down, and paint it up to seal it. You shouldn't have to worry about rust. it took me a healthy bit of sanding just to get to metal on mine.
  7. #7 Re: Where to ground amp?
    Nov 2011
    NY
    Strut bolt works, just make sure where any part of the bolt seats, that there's metal to metal contact. As mentioned, remove the paint there. Use a dialectric grease too on the surface, between bolt and washer, stud, whatever on that point that you ground. If no grease is available, simple petroleum jelly is ok as it will keep out moisture. This and you're good to go!
    I use dialectric grease on all my grounds and electrical connections under hood, at battery and alt too. Reduces chances for crap faulty grounds. ; )
  8. #8 Re: Where to ground amp?
    Pennsylvania
    I pour liquid gasket over my grounds. Never have to worry about accidentally getting greasy.
  9. #9 Re: Where to ground amp?
    I don't ground to something my mechanic has to move to replace a strut...or that's been a known source of issues on 97-03's..lol
    It's all good though.. keep taking the easy way out guys.
  10. #10 Re: Where to ground amp?
    Pennsylvania
    Your ground is bad and you should feel bad
    Fixt
  11. #11 Re: Where to ground amp?
    GT Level Member maverickdog8's Avatar
    Bettendorf, Iowa
    Negative of the front battery is the only ground I will ever use.
    Do the big 3 then ground to front battery.
  1. bad ground ??
    By GTPgurl in forum General Tech Discussion
    Last Post: 03-04-2011, 09:19 AM
  2. battery ground
    By gpgt04 in forum General Tech Discussion
    Last Post: 12-19-2010, 05:30 PM
  3. Amp Ground
    By X97prixX in forum Audio, Security & Visual Electronics
    Last Post: 11-11-2009, 08:14 PM
  4. Bad Ground???
    By jjokrm in forum General Tech Discussion
    Last Post: 01-25-2009, 07:44 PM
