Thread: Viper remote start Key Fob acting up?
Results 1 to 10 of 10
  1. #1 Viper remote start Key Fob acting up?
    GT Level Member Points70's Avatar
    Nov 2010
    Bellevue, Nebraska, United States
    So as of late my 2-way Viper Remote Start Key Fob has been acting up on my 2001 Grand Prix GT. I would push the unlock button and it would unlock and the car would honk twice as normal, then a couple seconds later the car would honk once more (Not typical behavior) and then the Key Fob would double beep every 5 or so seconds for 5 times. When it beeps the light at the bottom next to the F button on the remote would flash too. Same thing if I lock the car or open the trunk. What could be causing this? I thought it was telling me the battery was dead so I bought a new one and it is still occurring. Wondering if anyone else has had these problems?
  2. #2 Re: Viper remote start Key Fob acting up?
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    I believe it's saying a door trigger has been detected.
    That's the push of lock a few seconds later honk would be a notification the one of the door triggers still shows open.
    The remote flashes and beeps to notify you as well.
    Sent from my Galaxy SIII on Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  3. #3 Re: Viper remote start Key Fob acting up?
    Oct 2011
    MI
    Assuming your viper is a remote start/alarm combo
  4. #4 Re: Viper remote start Key Fob acting up?
    Well..you took my low battery fun away.
    Look up your model and see what the manual says.
    http://www.viper.com/Support/
  5. #5 Re: Viper remote start Key Fob acting up?
    Nov 2010
    Well, I dont have the actual alarm part on there but thanks for help. Would it still do that if all the doors are closed and I dont have an alarm? lol but Ill try to look it up on that support site thanks.
  6. #6 Re: Viper remote start Key Fob acting up?
    Oct 2011
    MI
    Do you have a picture of your keyfob or know the model number
  7. #7 Re: Viper remote start Key Fob acting up?
    Nov 2010
    Ok well i looked it up, it has the signs of a low battery like an extra honk after each button pushed along with sets of double beeps and the LED next to the Function light lighting up, but I bought 2 new batteries for it and they both dont fix the problem... Any other advice?
  8. #8 Re: Viper remote start Key Fob acting up?
    Nov 2010
    Its the 4204 model 2 way remote
  9. #9 Re: Viper remote start Key Fob acting up?
    Oct 2011
    MI
    Ahh. I thought you meant the car was beeping. If after every push of a button you get a double beep and a flashing at the function led it's never a good thing.
    you can try re-pairing/programming the remote to the brain but usually is a problem with the remote(s) or the actual brain itself. At the shop we would just swap it out for ya under vipers warranty but you'll have to call and get an RA number to ship it in for a fix. Usually they just send back a refurbished unit. GL.
  10. #10 Re: Viper remote start Key Fob acting up?
    Nov 2010
    Dang that doesn't sound good. But thank you I check for my warranty and see what I can do. Thanks again
  1. How do you program a Viper 479V remote?
    By 007 in forum Audio, Security & Visual Electronics
    Last Post: 12-21-2010, 12:53 PM
  2. Viper 160xvl remote start
    By 02Prix in forum Audio, Security & Visual Electronics
    Last Post: 12-02-2010, 06:46 PM
