This question has probably been asked many times but a search of the forum and quick look online turned nothing so I figured it couldn't hurt to ask it here one more time. So I have mounted my amp, ran the RCA and control wire to the head unit and ran a ground wire to a metal portion of the car. Then I took the power wire and ran it all the way to the front of the car under the trim and put all the trim back together. Here's the problem, now the power wire is sitting at the feet of the front passenger seat and I need to run it to under the hood to connect to the battery terminal. I can't seem to figure out the best way to do this, I can feel an area behind there that might be an easy place to drill into and run the wire through there but I don't exactly know what's behind it so I'm not so sure this is the best route to take. For those of you with GP's where did you run your power wire to your battery? I have a 2002 GP GT if that makes any difference. Thanks in advance.
