Thread: Window switch LED
Results 1 to 20 of 23
  1. #1 Window switch LED
    SE Level Member magnus's Avatar
    cedar rapids, ia
    Most of my window / door lock switches are burnt out, so I wanna swap them with LED. Anyone got a wiring diagram? Or pics of how you stuffed the resistors in there?
  2. #2 Re: Window switch LED
    cedar rapids, ia
    Got the door lock switch figured out. Power is on the left.
  3. #3 Re: Window switch LED
    cedar rapids, ia
    Coupe driver window switch. You have to unsolder 3 posts to get the board separated from the actual switch.
    Top is power.
  4. #4 Re: Window switch LED
    London Ont, Canada
    97-03? that conversion was a pain in the ass..
    the headlight selector switch was worse..
    taking it out causes the "key in ignition" noise to go off Constant
  5. #5 Re: Window switch LED
    cedar rapids, ia
    Yup, doing it in my 2000. It's not that bad once you figure out which side is what. I couldn't find any good pics or info so I figured I'd post what I found out.
    Haven't done the headlight one yet, working on the doors first
  6. #6 Re: Window switch LED
    It's Slow LS1GTP's Avatar
    Sep 2012
    Clarkston, MI
    Meh, I just went to the junkyard and pocketed all the switches I could find and now I have good switches.
  7. #7 Re: Window switch LED
    cedar rapids, ia
    Quote Originally Posted by LS1GTP View Post
    I did that too, but I took them all apart.
  8. #8 Re: Window switch LED
    London Ont, Canada
    yeah, i did a colour conversion in my 99
  9. #9 Re: Window switch LED
    cedar rapids, ia
    Passenger window. I already put it in, but power is on the right. I think.
  10. #10 Re: Window switch LED
    Jul 2010
    Coquitlam,BC,Canada
    Thanks for posting magnus. I noticed the other day that my passenger front door lock switch was not illuminating. I removed it when I got home today and will be off to the electronics store tomorrow. If I can do the right door without hurting myself, I will tackle the left door.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  11. #11 Re: Window switch LED
    cedar rapids, ia
    Drivers side at night
  12. #12 Re: Window switch LED
    Dec 2008
    Lawndale, CA
    Looking good.
  13. #13 Re: Window switch LED
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by The Guz View Post
    Looking good.
    I want to keep mine red. Off to get them supplies.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  14. #14 Re: Window switch LED
    Sep 2012
    Cedar Rapids, Iowa
    How did you remove the switch from the plastic piece?
  15. #15 Re: Window switch LED
    Howell, NJ
    There are plastic tabs holding the switch assembly to the plastic piece. Just pull them away from the switch
    Look on the underside of the piece the button slides out through the bottom
  16. #16 Re: Window switch LED
    Jul 2010
    Coquitlam,BC,Canada
    magnus, what are the specs on the LED's you used?
    I just got some that are:
    - red super bright LED
    - 2,000 mcd output
    - 1.8V @ 20mA
    - 15° Viewing angle
    I used 1W, 680ohm resistor (couldn't find any 1/2W 680ohm), and they aren't as bright as I was hoping for.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  17. #17 Re: Window switch LED
    cedar rapids, ia
    It might be the angle, the stock bulbs point straight up, the led you have to kind of angle to the switch a bit, especially if your viewing angle is kinda narrow.
  18. #18 Re: Window switch LED
    cedar rapids, ia
    I used 680 ohm 1/2 watt resistors too.
  19. #19 Re: Window switch LED
    Jul 2010
    Coquitlam,BC,Canada
    Ya, I am suspecting the angle also. I am going to finish the right switches and do a night comparison to the left side (stock).
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  20. #20 Re: Window switch LED
    cedar rapids, ia
    Quote Originally Posted by Bronco Boy View Post
    Cool. I've got one of mine that's dimmer than the rest, I'm pretty sure it's all in how aim to light up that little bit of clear plastic.
  1. Window switch
    By josemolina2008 in forum General Tech Discussion
    Last Post: 04-12-2010, 10:53 AM
  2. bad window switch help (GTP)
    By IndeedSS in forum General Tech Discussion
    Last Post: 07-26-2009, 11:23 PM
