Thread: Monsoon or not?
Results 1 to 12 of 12
  1. #1 Monsoon or not?
    Feb 2013
    Los Angeles
    Hey guys I'm having a very hard time figuring out how I should wire in my new amp and sub into my 1998 Grand Prix GT. I have the premium sound system with the extra tweeters and 6x9's in the rear, everything is stock though btw. I read that Grand Prix's with the premium sound have a monsoon amp a low-pass crossover that supplies the 6x9's. If my car has this system, then I want to tap into those low-pass wires to feed sound to my new amp and 13" woofers. So yeah can you guys let me know if my car actually has the monsoon and crossover and if I do where it is because I think I have it and I cant find it. Thanks in advance!
  2. #2 Re: Monsoon or not?
    Pennsylvania
    Quote Originally Posted by jakeanator View Post
    The monsoon amp is in the trunk, right under the 6x9's... where the lights are for the trunk, very center. It's just a black box, mine has the monsoon logo on it. Im not sure if earlier models of the monsoon had the speaker front and center in the dash, but mine has that.
    Sport Edition Kv5 18x8
  3. #3 Re: Monsoon or not?
    Pennsylvania
    The amp
    You can see here where the amp is next to the speaker.
    Front and center dash speaker.
    Better view for reference
  4. #4 Re: Monsoon or not?
    Feb 2013
    Los Angeles
    Quote Originally Posted by FriboRage View Post
    Yeah I can't find any box like that I guess the pre-2004 models don't have monsoon. How should I set up the amplifier to get sound then? My amp has RCA and Hi-Level inputs
  5. #5 Re: Monsoon or not?
    gardner,mass
    you would have to wire the amp in with power from battery a ground remote and then wire the speakers into the amp and use rcas to the back of an aftermarket deck or use a line out converter if your using the factory hu, just as if you were hooking up subs
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  6. #6 Re: Monsoon or not?
    Quote Originally Posted by Coleslaw View Post
    i just did this same thing, used a line out converter off the rear speaker for my amp and sub. but i dont have a mosoon set up.
    regal, concert sound. which means nothing its just a radio and speakers.
  7. #7 Re: Monsoon or not?
    Feb 2013
    Los Angeles
    @Coleslaw and @scotyydoggs
    Will this work then to convert from my factory hu and to control the level then? PAC LC2 Universal Bass Remote Level Control via Speaker Level I just wanted to make sure I can use these as kinda like a 2-for-1 deal because I've never heard of something that does both before.
    EDIT: On the website it says this converter "Cuts out low frequency noise below 20Hz." Wouldn't this be bad though because subwoofers are meant to pump out really low soundwaves below 20Hz? Or does that mean it just cuts out background noise?
    EDIT: I'm a noob sorry for the dumb question but yeah I got that hopefully it works
  8. #8 Re: Monsoon or not?
    this is the vid i followed, and pretty much the same part i got as well.
  9. #9 Re: Monsoon or not?
    SE Level Member Blacknitews6's Avatar
    May 2017
    south jersey
    So a 1998 Grand Prix GTP has a Monsoon amp with the 8 speaker setup?
  10. #10 Re: Monsoon or not?
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    Quote Originally Posted by Blacknitews6 View Post
    Technically it's not monsoon, it's Delco. It only powers the rear speakers and is very weak. The trunk mount is bose which is slightly better. You can tell by your rear deck. If you have quad rear deck speakers and no black trunk amp on trunk roof, you have the Delco system behind the glove box, and if you just have the 6x9s on the rear shelf, you have neither. Wires are ran completely different.
  11. #11 Re: Monsoon or not?
    May 2017
    south jersey
    The system in the car is listed as "Premium Sound System" is that the Delco?
  12. #12 Re: Monsoon or not?
    Aug 2017
    Raytown, MO
    I would assume so. If you have two or four speakers behind the passenger seat, 90% yes, and definitive option is pinch in on either side of your glove compartment and drop it down. Amp should be small grey box, or if it's already removed, you'll see one or two connectors loose.
  1. Keep the Monsoon amp or no?
    By Infinity9999 in forum Audio, Security & Visual Electronics
    Last Post: 12-25-2012, 11:35 PM
  2. Will Monsoon 6 Disk Changer function in Non-Monsoon Vehicle?
    By SlprGS in forum Audio, Security & Visual Electronics
    Last Post: 08-02-2012, 10:16 PM
  3. Monsoon Q
    By flash527 in forum Audio, Security & Visual Electronics
    Last Post: 05-09-2011, 10:14 AM
  4. Monsoon?
    By Berger in forum Audio, Security & Visual Electronics
    Last Post: 05-02-2008, 11:29 AM
