hey everyone i have realized that the grounds on my amps are not the best therefor i plan on fixing this very soon. however in my research and reading i have found mixed results. some say to ground both amps to the same location to avoid ground loops, however some say the complete opposite. Do any of you guys have opinions on this? in my set up, i dont believe that the short 18in however short ground wires are long enough to touch each other in order to be grounded together i do have them grounded decently far apart for this reason... so my first question is with two amplifiers do you ground them together or seperate or does it matter? my second question would be your opinions on the best way to ground. the ring terminals are too small to fit on my seatbelt bolts i also dont believe they will reach or fit on my strut tower, therefore i have them grounded under the back seat in my 05 gp. i have heard that using a self tapping bolt/screw and a star washer is the best way to go after removing all the paint. thanks for the responses guys!
