Thread: Help me with trunk lighting
Results 1 to 20 of 22
  1. #1 Help me with trunk lighting
    Yoga city
    Hey everyone, im running into one issue and not sure what to do. I ended up with a bunch of 1m led strips and want to use it in my trunk. well this isnt the first time ive had this issue. MY 97 also had low voltage to the trunk, when i plug in the strip its super dim, or peanut style bulbs just flicker. What can i do to get that perfect 12volt when the trunk is opend?
  2. #2 Re: Help me with trunk lighting
    GT Level Member Utter99's Avatar
    Warsaw indiana
    Do you happen to have subs ? Can you split a wire from the power wire and run it to them?
    MY LUGNUTS REQUIRE MORE TOURQE THAN YOUR HONDA PUTS OUT!!!
  3. #3 Re: Help me with trunk lighting
    Yoga city
    are you kidding me? im not going ghetto like that, trying to figure out to get the latch to work. need 12 volts
  4. #4 Re: Help me with trunk lighting
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by Utter99 View Post
    Why would you want your trunk light to come on with your subs?
    JTeske88, the BCM controls the trunk light, so I would wager that you have a bad BCM, a bad wire, or a bad ground.
    You could also check the harness at the trunk latch, on the lid. I had intermittent issues (dim light, no light etc) that turned out to be up there; one of the pins in the connector was loose, and wiggling the harness made the light come on. After squeezing the pins so they fit tighter, it hasn't failed me.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  5. #5 Re: Help me with trunk lighting
    Warsaw indiana
    Well on mine the switch that turns the light on to the trunk is connected to the ground side . So the wire to the light is always hot and when the switch is grounded it grounds the light and viola the light comes on .
    Now since your loosing voltage somewhere in the line if you re energize it by using the next best wire in the trunk it would be your subs power wire you will have the steady voltage .
    I'm not sure if the switch is on the ground on the 04 plus or the power .
    Not so ghetto as you thought? One wire that's easily hidden...
  6. #6 Re: Help me with trunk lighting
    Warsaw indiana
    Not the amp turn on wire the constant 12 volt
  7. #7 Re: Help me with trunk lighting
    Yoga city
    im not doing that, i have 2/0 gauge wire. and it will burn it up.
  8. #8 Re: Help me with trunk lighting
    Yoga city
    i like what your saying, ive got 11 volts. maybe its the ground.
    Quote Originally Posted by Bronco Boy View Post
    You could also check the harness at the trunk latch, on the lid. I had intermittent issues that turned out to be up there; one of the pins in the connector was loose, and wiggling the harness made the light come on. After squeezing the pins so they fit tighter, it hasn't failed me.
  9. #9 Re: Help me with trunk lighting
    GTX Level Member blakgtp's Avatar
    Sep 2011
    Vancouver
    use a relay , use the trunk wire as the signal.
    97 gtp- 3.5 pulley, sd headers, autolite 104's, dhp pcm, hai, 180 t-stat SOLD
    94 skyline- drift slut SOLD
    97 rx7 fd3s twin turbo SOLD
    99 R34 skyline
  10. #10 Re: Help me with trunk lighting
    Jul 2010
    Coquitlam,BC,Canada
    Ah, that makes more sense.
    Quote Originally Posted by blakgtp View Post
    For me, this was my worst case repair. I'd rather repair the problem and not run new wires.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  11. #11 Re: Help me with trunk lighting
    I'll post the Jayke type response.
    Get a flashlight.
  12. #12 Re: Help me with trunk lighting
    Jul 2010
    Coquitlam,BC,Canada
    Get a flashlight.
    He-he. I had one of these in my trunk until I got things figured out.....
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  13. #13 Re: Help me with trunk lighting
    Grand Prix owners...lol
  14. #14 Re: Help me with trunk lighting
    Yoga city
    dont make sense, i think its the ground. the same leds in my house are on 9v and look great. in my car on the 11.9 that the trunk gives it no dice. Wheres the ground location again? or how does the trunk latch work.
  15. #15 Re: Help me with trunk lighting
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by JTeske88 View Post
    Try these.....
    Plug #1 on the trunk lid was where my loose connection was.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  16. #16 Re: Help me with trunk lighting
    Yoga city
    hahaha im a dumazz, i have a service manual and its for a 05 gxp by the way
  17. #17 Re: Help me with trunk lighting
    Wow, that would seem too easy.
  18. #18 Re: Help me with trunk lighting
    Jan 2013
    Sioux Falls, SD
    Yeah my GP doesnt have a trunk light, kind of weird. I was thinking LED strips too.
  19. #19 Re: Help me with trunk lighting
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by trojanone1 View Post
    I said that too.
    Don't think. Do!
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  20. #20 Re: Help me with trunk lighting
    Did they cheap out that much on the GP ... oh wait, I know this answer.
    Jayke..you figure this out yet?
  1. Trunk Lighting????
    By nikkigpgt00 in forum Audio, Security & Visual Electronics
    Last Post: 01-19-2013, 08:58 PM
  2. Replies: 21
    Last Post: 01-31-2012, 08:48 AM
  3. Help with lighting please
    By sinceregtp in forum Visual/Body Modifications
    Last Post: 04-15-2010, 10:59 PM
  4. Lighting Questions (HID & Fog)
    By bigbair45 in forum Visual/Body Modifications
    Last Post: 03-19-2010, 10:34 AM
  5. LIGHTING for an 04 GTP
    By ne04gtp in forum Shops and Community Heroes
    Last Post: 02-05-2010, 05:49 PM
