Going to be building an enclosure for the 15" fi bl fully loaded that has been sitting in garage for the past couple weeks. Going into the 97 gtp. Aiming for 5 cubes net with aero ports. Probably tuned around 32hz. Going to be feeding it 2200 watts. Will be sliding it in from the front (back seats are removed). Dimensions to work with based on the opening that I will be sliding it in from is 13" height, 31" width, and 38" depth. Sub will be facing up firing through the rear deck (rear speakers are removed), just debating on where to put the port? I'm thinking either on the side as far back from the cabin as possible, firing up through the deck lid, or firing forward. Wondering what the pros and cons would be of each option.
option 1: port side
option 2: port up
option 3: port forward
This is going in the daily driver, not for comps or anything.
