Thread: enclosure for 15" fi bl
Results 1 to 20 of 38
  1. #1 enclosure for 15" fi bl
    GTX Level Member blakgtp's Avatar
    Sep 2011
    Vancouver
    Going to be building an enclosure for the 15" fi bl fully loaded that has been sitting in garage for the past couple weeks. Going into the 97 gtp. Aiming for 5 cubes net with aero ports. Probably tuned around 32hz. Going to be feeding it 2200 watts. Will be sliding it in from the front (back seats are removed). Dimensions to work with based on the opening that I will be sliding it in from is 13" height, 31" width, and 38" depth. Sub will be facing up firing through the rear deck (rear speakers are removed), just debating on where to put the port? I'm thinking either on the side as far back from the cabin as possible, firing up through the deck lid, or firing forward. Wondering what the pros and cons would be of each option.
    option 1: port side
    option 2: port up
    option 3: port forward
    This is going in the daily driver, not for comps or anything.
    97 gtp- 3.5 pulley, sd headers, autolite 104's, dhp pcm, hai, 180 t-stat SOLD
    94 skyline- drift slut SOLD
    97 rx7 fd3s twin turbo SOLD
    99 R34 skyline
  2. #2 Re: enclosure for 15" fi bl
    GT Level Member Dakoda's Avatar
    Feb 2013
    Illinois
    why are your seats and speakers removed?
  3. #3 Re: enclosure for 15" fi bl
    GT Level Member Erik Adam Rodriguez's Avatar
    Sep 2012
    bridgeport,NY
    i removed mine and it made a big difference when the sub hit
    02 grand prix gt- L67 swap, ZZP 1.0 pcm, thrasher CAI, SLP 2.5 catback, A/C delete, 02 emulator, poly dog bone mounts, 6000k projectors with CCFL halos, 12 in slotted front rotors, ported blower and intake, evap and EGR deleted, 12" kicker cvr with 1000 watt amp, alpine cda 9886 deck
  4. #4 Re: enclosure for 15" fi bl
    Sep 2011
    Vancouver
    Quote Originally Posted by Dakoda View Post
    so I can pressurize the cabin instead of my trunk lid
    99 R34 skyline
  5. #5 Re: enclosure for 15" fi bl
    Sep 2011
    Vancouver
    Quote Originally Posted by Erik Adam Rodriguez View Post
    previous setup was sub and port firing forward, and it was much better with the rear seat removed. What I'm thinking now though, since the sub will be firing up through the deck, is I could have the port positioned so it would fire into the ski pass for when I put the rear seat back in.
    99 R34 skyline
  6. #6 Re: enclosure for 15" fi bl
    Sep 2012
    bridgeport,NY
    i have port and sub facing rearward. i leave the rear center peice folded down and roll both front windows down and pop the moon roof. dbs are round 90 to 110. this summer im gunna do a monster 6x9 upgrade get it screaming instead of shaking
  7. #7 Re: enclosure for 15" fi bl
    Feb 2013
    Illinois
    ^^ i have two 12s in my trunk with the center piece folded down and the windows down it sounds amazing... loud and clean
  8. #8 Re: enclosure for 15" fi bl
    Sep 2012
    bridgeport,NY
    now if i can just find that change that is rattling in my door
  9. #9 Re: enclosure for 15" fi bl
    Sep 2011
    Vancouver
    I can't do 5 cubes sub back or front unless i build in the trunk
    99 R34 skyline
  10. #10 Re: enclosure for 15" fi bl
    SE Level Member timreams's Avatar
    Aug 2011
    Southwest of Pittsburgh
    you said your width is 31" how much space will that leave between the box and your fender wells? and what size...how many...aero ports are you using?
    generally speaking you will get better response in the lower frequencies if you have something solid for the port to load on, i.e. the back of the trunk or the fender well. if you fire the port directly into the cabin you will still get decent response but not as good. Or you can tune lower and fire forward.
    Also what type of music to plan to play and from what type of media?
  11. #11 Re: enclosure for 15" fi bl
    Sep 2011
    Vancouver
    Up firing into the rear deck will load off the rear window. if i do side port i'll make the box less wide. 31 is just how wide it can be based on the opening i'll be sliding the box in from. i'll be tuning the box around 32hz. Using 6" ports or an 8"
  12. #12 Re: enclosure for 15" fi bl
    Aug 2011
    oh yeah if you are talking about actually firing through the rear deck onto the windshield i say go that route. a lot of people say that but just point the port toward the rear deck, if you are literally coming through the rear deck that should sound pretty sick. and if you are so inclined....will also make for some sweet vids of the rear windshield flexing.
  13. #13 Re: enclosure for 15" fi bl
    Sep 2011
    Vancouver
    decided, I'll be doing sub up port side. 5 cubes net. 6" aero port tuned to 31hz
    99 R34 skyline
  14. #14 Re: enclosure for 15" fi bl
    Aug 2011
    Why did u decide port side?
  15. #15 Re: enclosure for 15" fi bl
    Sep 2011
    Vancouver
    Quote Originally Posted by timreams View Post
    I talked to a few spl guys who have done builds in grand prixs and they said this will work well. I had a bit of a mind fart when i put "port up" as an option, since i'm using aero ports and my box will only be 12" high, that obviously won't work. so it was either back, forward, or side. I chose side, but it will be at the very back of the box, and the sub will be directly under the deck lid holes.
    99 R34 skyline
  16. #16 Re: enclosure for 15" fi bl
    Aug 2011
    Yeah that should perform well. I have mine currently set up for port and subs toward the cabin but i have my trunk completely sealed off from the cabin and my box has 2 ports, i can close one off to switch from spl tuned to daily.
  17. #17 Re: enclosure for 15" fi bl
    Dec 2012
    Hawai'i
    I have sub up port back in my impala and it kills the lows. As long as you leave enough room on the side it should be good. Have you braced the rear deck? Sub up is gonna rattle the deck like a mofo. I'd deaden on top and put mdf on the bottom, with holes for the air to pass thru. Or don't put holes and get some 6th order action going
  18. #18 Re: enclosure for 15" fi bl
    Sep 2011
    Vancouver
    just needs to be carpeted
    4.7 cubes net, 68.25 sq in of port, tuned to 30hz
    99 R34 skyline
  19. #19 Re: enclosure for 15" fi bl
    Dec 2012
    Hawai'i
    What's the dimensions of that? Did you test that you could get it in there?
    2002 Impala- SSC, AGX, 18" charger R/t rims w/8mm spacers, Magnaflow cat, U-bend delete, flowmaster 80 series crossflow, z28 tips, HAI, debadged, 35% tint, smoked headlights, full sound system
  20. #20 Re: enclosure for 15" fi bl
    Sep 2011
    Vancouver
    dimensions are 12"h 31"w 38"d, I will be sliding it in from the front (back seat opening).
    99 R34 skyline
  1. Dimensions for 12' Sub Enclosure
    By JShields14 in forum Audio, Security & Visual Electronics
    Last Post: 07-04-2012, 01:20 PM
  2. Custom Subwoofer Enclosure
    By 2dee11 in forum Audio, Security & Visual Electronics
    Last Post: 04-23-2012, 05:03 PM
