Thread: Hardwiring GPS
Results 1 to 12 of 12
  1. #1 Hardwiring GPS
    Jan 2013
    Iowa
    Does anyone know where to hardwire a GPS in the fuse box so that it turns on and off with the car?
  2. #2 Re: Hardwiring GPS
    GT Level Member Erik Adam Rodriguez's Avatar
    Sep 2012
    bridgeport,NY
    try using your switched 12v at the radio
    02 grand prix gt- L67 swap, ZZP 1.0 pcm, thrasher CAI, SLP 2.5 catback, A/C delete, 02 emulator, poly dog bone mounts, 6000k projectors with CCFL halos, 12 in slotted front rotors, ported blower and intake, evap and EGR deleted, 12" kicker cvr with 1000 watt amp, alpine cda 9886 deck
  3. #3 Re: Hardwiring GPS
    Jan 2012
    Philadelphia
    Use one of the add-a-fuse things you can buy them at Autozone
    Cooper Bussmann/ATM fuse tap (BP-HHH-RP) | | AutoZone.com
  4. #4 Re: Hardwiring GPS
    Sep 2012
    bridgeport,NY
    he wants power when the key is turned on so a switched 12v source is required
  5. #5 Re: Hardwiring GPS
    Jan 2012
    Philadelphia
    put the add a fuse in where the radio fuse is
  6. #6 Re: Hardwiring GPS
    Sep 2012
    bridgeport,NY
    ^this
  7. #7 Re: Hardwiring GPS
    Jan 2013
    Iowa
    Alright, thanks fellas
    I live here. DirtDog's Avatar
    Jun 2012
    I actually did mine with the ignition wire. Its wasn't hard to wire in...costs me 20 bucks at a local audio store. They did it perfectly and I live it that way
    Sent from my DROID RAZR using Tapatalk 2
  9. #9 Re: Hardwiring GPS
    Feb 2013
    Indianapolis
    im a noob so I really might sound dumb, but im interested in hardwireing some new LED lights I got. if you replaced the radio fuse with the add a fuse. wouldn't you loose the radio?
  10. #10 Re: Hardwiring GPS
    Ocala, FL
    Quote Originally Posted by OLD ROUNDHEAD View Post
    "ADD" a fuse. You're not replacing the fuse with a new one, but it adds a second fuse.
  11. #11 Re: Hardwiring GPS
    Feb 2013
    Indianapolis
    Ahhhhhhhh I see lol thanks
  12. #12 Re: Hardwiring GPS
    Sep 2011
    Copperas Cove, TEXAS
    Plug into power, with external power lead done and done, googled and got this
    Add-a-fuse
