I have a 2001 GTP with the stock 105 or 110 amp alternator. For a while now ive had voltage regulator issues but not to the point that its not charging anymore. Sometimes in the morning the battery light is on and my volt meter in the trunk says 11 volts. After about 10 seconds its back to normal. I recently upgraded my sound system and have an amp that makes real power (compared to the old one) I just did the "big three" (or four in this car) upgrade to get the most out of this alternator. But it just doesnt make enough power plus the regulator issue.
So ive been browsing rock auto looking for a stock ac delco alternator. I dont think i need to go aftermarket h/o. I found the replacements for this car is 105 or 110. The buick park avenue ultra uses 125 amp. But the buick riviera uses 140 amp. I know these other alternators will bolt up but will the wiring harness plug in? I know there is a mod some do to get and extra 0.5-1.0 volts on certain years and it requires adding a pin to the harness. I just want to know if the riviera alternator is compatible with an 01 GTP. Or if there are other alternators that fit this motor without modification and is under $180 making 140 amps or more. The 140 amp ac delco riviera alternator on rock auto is $150 or $160
Ive been searching for this for about a month. Google, forums, everywhere. Also ive been leaning towards stock ac delco for reliability reasons. Ive had AWFUL luck with alternators in the past and want something i know is going to work.
Sorry if this has been asked already, I just cant find the answer anywhere.
