Thread: Stock alternator options?
Results 1 to 17 of 17
  1. #1 Stock alternator options?
    Jun 2011
    Pepperell MA
    I have a 2001 GTP with the stock 105 or 110 amp alternator. For a while now ive had voltage regulator issues but not to the point that its not charging anymore. Sometimes in the morning the battery light is on and my volt meter in the trunk says 11 volts. After about 10 seconds its back to normal. I recently upgraded my sound system and have an amp that makes real power (compared to the old one) I just did the "big three" (or four in this car) upgrade to get the most out of this alternator. But it just doesnt make enough power plus the regulator issue.
    So ive been browsing rock auto looking for a stock ac delco alternator. I dont think i need to go aftermarket h/o. I found the replacements for this car is 105 or 110. The buick park avenue ultra uses 125 amp. But the buick riviera uses 140 amp. I know these other alternators will bolt up but will the wiring harness plug in? I know there is a mod some do to get and extra 0.5-1.0 volts on certain years and it requires adding a pin to the harness. I just want to know if the riviera alternator is compatible with an 01 GTP. Or if there are other alternators that fit this motor without modification and is under $180 making 140 amps or more. The 140 amp ac delco riviera alternator on rock auto is $150 or $160
    Ive been searching for this for about a month. Google, forums, everywhere. Also ive been leaning towards stock ac delco for reliability reasons. Ive had AWFUL luck with alternators in the past and want something i know is going to work.
    Sorry if this has been asked already, I just cant find the answer anywhere.
  2. #2 Re: Stock alternator options?
    Mar 2012
    NC
    You can build a high output unit for relatively cheap. Your car comes with the GM CS130D alternator. Google it up and you'll find rebuild kit options anywhere from 180-220A for like $100.
  3. #3 Re: Stock alternator options?
    Jun 2011
    Pepperell MA
    Hmm that is a tempting option. I imagine a rebuild kit would also include a regulator or at least the option to add it to the kit. Since not everyone needing a rebuild needs a regulator.
  4. #4 Re: Stock alternator options?
    Mar 2012
    NC
    Exactly. It's an easy job and A LOT cheaper than buying one already built. I'll be looking into this option for my Bonnie alternator soon.
    Any idea what a 04 has as far as the GM code?
    04 Comp G.
  6. #6 Re: Stock alternator options?
    Mar 2012
    NC
    I'll look it up and let you know.
    EDIT: Physically, it looks like the 99-03 alternator. I can't tell about the connections on it. I haven't found anything regarding a high output unit, but you might be able to contact powermaster and see if they have any good info.
    Will do thanks. Been wanting to upgrade without paying the $250+ cost for a HO. Difference is mainly its a 4 prong connection instead of the usual 2.
    04 Comp G.
  8. #8 Re: Stock alternator options?
    Nov 2011
    NY
    GT Level Member maverickdog8's Avatar
    Bettendorf, Iowa
    ^^ stay away from power bastards.
    Mechman
    Singer alternators
    Excessive amperage
    Ohio generators
    Tenney alternators
    Irragi
    Any of those company's build high outputs. You get what you pay for in that field just as most others car related.
  10. #10 Re: Stock alternator options?
    That Loud Guy 1LoudGrandPrix's Avatar
    Cedar Rapids, IA
    Ohio should have there 3800 grand prix one out soon i got the test fit, shes a beast 300A hot at 14.4V
    98 Camaro SS 46k LS1, T56, All Stock. 00 GMC Sierra 2wd ECSB 106k Lm7, 3.73s tow needs lowered..
    01 Grand Prix GTP "201k" ~111k on motor, ~46k on trans, headers, 3.4 and a tune to come.
    01 Grand Prix GT 168k: Mods: Tune by TheOtherNick. Stereo: 320A alt,4 runs 0/1, XS D3400 front, 1 JYP 80ah Lithium rear, 2 Twisted Sounds 3500s, 2 Sundown Audio NightShade v.3 7 National Records..
  11. #11 Re: Stock alternator options?
    Yoga city
    but whats the output at idel?
  12. #12 Re: Stock alternator options?
    Nov 2011
    NY
    Quote Originally Posted by JTeske88 View Post
    A Helluva lot more than a stock unit, lolz!
    Sorry, couldn't resist!
    Bettendorf, Iowa
    Quote Originally Posted by 1LoudGrandPrix View Post
    They have had one for the Grand Prix for a long time now. My team mate had one almost a year and a half ago.
    Bettendorf, Iowa
    Usually from 140-160 amps. Sometimes more and usually not less.
  15. #15 Re: Stock alternator options?
    May 2012
    United States
    Quote Originally Posted by Sven Sexman View Post
    Cool! do you know what alternator a 2006 base grand prix has? i'm definitly interesting in spending 100 bucks to get it to 180, if its possible.
  16. #16 Re: Stock alternator options?
    Cedar Rapids, IA
    200 iirc ~1600rpm is 300
  17. #17 Re: Stock alternator options?
    Jun 2011
    Pepperell MA
    Update. I decided not to rebuild the stock alternator and instead ordered a 145 amp alternator for a 97 Buick Riviera which also has the L67. Turns out DOES NOT FIT. Looks like they used a completely different body for the alternator. Different mounting points. I didnt think to check pictures on google images before making the decision to order it. Now I have two options. Either send it back and hopefully get a refund or try to take it apart and use the insides since they are supposedly the same thing. I would imagine this Riviera alt is a CS130D just different body? Either way its kind of dumb of GM to make a different bodied alternator for the same motor. Pictures of a 97 GTP shows an alt that looks just like the one in my 01 GTP. Even the Buick Park Ave Ultra looks like the same alt as the GTP. Im pretty sure that one is 125 amp. Unless because the Riviera was the first car to use the L67 in 1996 maybe it was before they decided to use the Cs130d and the one I ordered is actually just the CS130 and they kept it because the Riviera motor was already setup for that mounting style.
  1. Rad Options.
    By matt5112 in forum General Tech Discussion
    Last Post: 07-28-2011, 10:15 AM
  2. H.O. Alternator dims more than stock
    By shawnschuldt in forum Audio, Security & Visual Electronics
    Last Post: 02-11-2011, 01:34 PM
  3. '97-'98 alternator options
    By DanGTP in forum General Tech Discussion
    Last Post: 01-05-2010, 07:15 AM
  4. HO Alternator options?
    By Luda in forum Audio, Security & Visual Electronics
    Last Post: 09-03-2009, 02:59 PM
  5. 2000 GTP stock alternator?
    By MysticStyl3z in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-09-2008, 11:39 PM
