Thread: Sub amp problems. Possible ground location??
Results 1 to 20 of 28
  1. #1 Sub amp problems. Possible ground location??
    GT Level Member comatoast's Avatar
    Nov 2012
    MN
    Just ran all the wire in my 06 gt. I'm gonna do some testing with the dmm tomorrow but and especially a DC test at the amp to make sure it's seeing 14 volts. But I grounded the amp the the black bar underneath the seat where the seatbelt bucks are attached to. Everything else on the car seems almost like plastic. So is that a decent ground spot , if not where did you guys ground too?
  2. #2 Re: Sub amp problems. Possible ground location??
    It's Slow LS1GTP's Avatar
    Sep 2012
    Clarkston, MI
    Not sure if your car is the same as 97-03, but I grounded mine on the fuel pump access panal under the carpet. Working just fine.
  3. #3 Re: Sub amp problems. Possible ground location??
    GTP Level Member simbah's Avatar
    Lala land
    Strut mounting bolts located on top of strut tower is a favorite grounding spot.
    'When someone shares something of value with you and you benefit from it, you have a moral obligation to share it with others
  4. #4 Re: Sub amp problems. Possible ground location??
    Nov 2012
    MN
    Under the hood reads 13.86 volts. As well as at the amp. The remote/ground on the amp reads 13.35. Is that low?
  5. #5 Re: Sub amp problems. Possible ground location??
    Sep 2011
    Arkansas
    Nope. Not low at all.
    1978 F250 2wd (460 c.i.d. / C6)- soon to give up the powerplant to an '80-'86 F150
    White 2000 Grand Prix GT coupe
    One still slow and loud... other one scoots just a bit.
  6. #6 Re: Sub amp problems. Possible ground location??
    SE Level Member Bologna's Avatar
    Oct 2011
    Illinois
    I ground mine at the seat belt bolts on the bottom, best ground imo.
    Also if there is paint on your grounding spot it will not work very well. Take some steel wool to it and make it shiny.
    Also, is your amp going into protect mode or not? (red light vs. green light)
  7. #7 Re: Sub amp problems. Possible ground location??
    Nov 2012
    MN
    Quote Originally Posted by Bologna View Post
    No. It's all green. And the only reason I thought 13.8 was low was because amps are rated at 14.4 volts.
    Also are you guys running lead or agm batteries
  8. #8 Re: Sub amp problems. Possible ground location??
    Yoga city
    seat belts post if by far the worst place to ground at. Go get your self some sandpapper and remove a strut bolt, then sand area so there is metal to metal, not paint to metal. Even know you will have some voltage drop when reading your points, it will show its true colors once you start playing on your set up hard. Voltage drop equals heat and that in turn fries the amp.
  9. #9 Re: Sub amp problems. Possible ground location??
    Yoga city
    And i might add that are cars voltage will vary from 12.8 to 15.00 depending on how the car feels lol i recomend getting a volt meter for sure
  10. #10 Re: Sub amp problems. Possible ground location??
    Nov 2012
    MN
    Hmmmm.
    So how will I get voltage drop from moving the ground toa "better spot"? And I'm not on the seat belt bolt. I sanded down part of the black bar and drilled through that. I drilled through the part that curves up in about the middle of the passenger seat.
  11. #11 Re: Sub amp problems. Possible ground location??
    Yoga city
    Im just saying the seat belt post is not a good ground if your trying to pull more than 1k watts. I had originally did that and got to the point where there was too much drop. so i did the BIG 3 and relocated my rear ground. But then again all my power/ground wire 2/0 awg wire
  12. #12 Re: Sub amp problems. Possible ground location??
    Nov 2012
    MN
    I still think my alt is bad regardless. I got a new ac Delhi 750 cca 120 rc battery and when I went to autozone to test my alt they couldn't do it apparently because my battery was low. So how does it discharge that much in one day?
  13. #13 Re: Sub amp problems. Possible ground location??
    Nov 2012
    MN
    Also post a pic if you have one of your power / ground wire and amp setup.
  14. #14 Re: Sub amp problems. Possible ground location??
    Yoga city
    whos setup you looking to see?
  15. #15 Re: Sub amp problems. Possible ground location??
    Nov 2012
    MN
    Quote Originally Posted by JTeske88 View Post
    Anyone's. just wanna see how everyone ran their wires
  16. #16 Re: Sub amp problems. Possible ground location??
    Oct 2011
    Illinois
    Quote Originally Posted by comatoast View Post
    They rate the amps at 14.4 because they higher the volts = more watts from the amp. Some car audio companies rate their equipment around 12.x volts to make it more realistic.
    13.8 is perfectly normal. And I disagree with the seat belt bolt being a bad bolt. With the proper cleaning of it - I couldn't think why it would be bad. I've always done it from there
    Also if your alternator was bad you wouldn't be able to drive your car because nothing would be recharging your battery. Check your battery voltage now and see what it says after driving it. Anytime from 12 down is bad imo
  17. #17 Re: Sub amp problems. Possible ground location??
    Nov 2012
    MN
    Thanks man. At idle with heater and radio on low volume the voltage under the hood matches back at the amp. 13.8 volts or so. Just making sure it wasn't a bad alt battery or ground since sears napa and interstate suggested these cars use a agm battery and that if you used a lead acid you would have voltage drop
  18. #18 Re: Sub amp problems. Possible ground location??
    Oct 2011
    Illinois
    I would use agm, but the different type of batteries won't give you a voltage drop.
    The reason people suggest agm is because if you have a lead acid battery in your trunk, you don't want it to fall over and ruin everything lol
    I run/suggest XS Power Batteries - They have never been outperformed by anyone as far as I know
  19. #19 Re: Sub amp problems. Possible ground location??
    Nov 2012
    MN
    But this is under the hood they were suggesting agm for.
  20. #20 Re: Sub amp problems. Possible ground location??
    Oct 2011
    Illinois
    I'd just ignore it, for a dd you will be fine with that battery up front.
  1. bad ground ??
    By GTPgurl in forum General Tech Discussion
    Last Post: 03-04-2011, 09:19 AM
  2. Amp Ground
    By X97prixX in forum Audio, Security & Visual Electronics
    Last Post: 11-11-2009, 08:14 PM
  3. Engine wiring harness ground location?
    By PCweber in forum General Tech Discussion
    Last Post: 09-24-2009, 01:10 PM
  4. Bad Ground???
    By jjokrm in forum General Tech Discussion
    Last Post: 01-25-2009, 07:44 PM
