Thread: Quick Splice connectors with remote start..
Results 1 to 6 of 6
  1. #1 Quick Splice connectors with remote start..
    GT Level Member Peacher213's Avatar
    STL Metro Area
    Im ordering this either today or tomorrow...So, Im about to order a remote start/alarm for my 99gtp. This to be exact.. Crimestopper SP 301 2 Way Remote Alarm Keyless Entry Security System w LCD Pager | eBay Now, can I use quick splice connectors for things such as door locks, turn signals, and other small current things? I will solder the 12v constant, ground and accessory wires. It'd sure be nice to not have to manually cut and solder any more connections than needed.
    99 GTP coupe
    Stock, other than open cone filter.
  2. #2 Re: Quick Splice connectors with remote start..
    Don't cut. Get yourself a decent set of wire strippers and pull the coating back. A buddy who used to do alarms showed me the second best thing to soldering. You strip some coating off the wire, poke a hole into it with a pick, put the wire you are adding on through the hole, close the hole and wrap your new wire end around the closed connection. Tape and smile.
    I am not a fan of splices as they cut through the wire you are tapping into and can cause issues over time.
    FWIW all the connections on my Viper system are soldered.
  3. #3 Re: Quick Splice connectors with remote start..
    Yoga city
    i like what bill said here, but i choose a lighter as stripper of choice on small gauge wire. But i like to soilder so im just do it.
  4. #4 Re: Quick Splice connectors with remote start..
    Houston
    Thats exactly how I was taught. I believe it's called a military tap. After I tape it, I put a zip tie around the wire I tapped into and the alarm wire. This will secure it so the wire can't be yanked out and the tape will not come undone.
  5. #5 Re: Quick Splice connectors with remote start..
    Crap..I forgot the zip tie. He did that too.
    GTP Level Member apierce1289's Avatar
    United States
    You need a heavy duty soldering gun for the ignition wires or you'll end up with a cold solder joint.
    List of wire locations---> http://db.tt/HWwaJctT
    Most wires are located at the bcm. Here's a picture of what you'll see and that's where most of the wires are at (such as drivers door trigger, factory disarm, lock and unlock wires). I just did this on my 2002 grand prix. So I'm hoping this info will keep you from being frustrated like I was. Testing every single connection in the drivers kick panel is a pain (the specific information I needed wasn't readily available so had to spend lots of time testing wires). Also get a test light which kinda looks like a screwdriver but with a sharp needle like tip at the end (don't use it on airbag wires and data wires!!). This way you can probe the multiple colored wires at the bcm (example: door unlock wires when probed will actuate door lock so you will hear the lock. You basically are grounding the test light to the chassis and completing the circuit. This is faster and easier than a digital multimeter!). Also use trunk release at the switch in glove box.
    BCM-->
    Big connector on the right not the little one to the left.
    This is passenger door trigger location (not drivers door trigger)--->
    Trunk release relay for negative trigger---->
    Any other questions just ask.
    Sent from my DROID RAZR using Xparent Red Tapatalk 2
    Gremlins always seem to show up in pairs, or groups of three with our cars...
  1. Remote Start???
    By nikkigpgt00 in forum Audio, Security & Visual Electronics
    Last Post: 08-03-2010, 11:09 PM
  2. Remote Start
    By RideMr2 in forum General Tech Discussion
    Last Post: 05-15-2010, 11:09 PM
  3. 02 GP Remote Start
    By Volvit in forum Audio, Security & Visual Electronics
    Last Post: 11-21-2009, 05:15 PM
