Thread: HID DRL issue
Results 1 to 10 of 10
  1. #1 HID DRL issue
    SE Level Member bziggy58's Avatar
    Apr 2011
    Minnesota
    I seen alot of posts about this but was wondering if anyone found a way to easily disable the drls on an 08 grand prix base model. I put the relay harness in with the hids but I still get the relay clicking like crazy and drls flash. Any idea at all to fix this?
  2. #2 Re: HID DRL issue
    GTP Level Member gpse2000's Avatar
    Apr 2011
    Fargo
    Ahah we be on the same boat son, I forked over money for a relay and it didn't help me one bit. best way to disable is disconnect the sensor on the dash but then all your lights come on all the time as if it was nighttime which I don't like,
    So what I had been doing and guess I will keep doing is flicking off the headlights during the day which becomes a pita
    are relays less hard on the system or not?
    2002 Denali Airaid MIT, Tint, 121k GARNET RED
    2006 GT S/C CAI, Plog, 3" DP, Flipped Mounts, DR STBs, SPO Grilles, SPO TIPS, Tint, Inlays, 120k BLEEN FOR SALE
    2000 SE 3.8 intake, dic swap, debadged, flipped mounts, rust mod 140k SILVERMIST SOLD
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    04+ has a solid state module that looks just like a relay in the under hood fuse box. It supplies 70% during the day 100% at night. Works great for a day time running like system. Bad for a ballast that requires a good battery some source.
    This also effects hid relay kits as the relay that triggers a good battery source you've wired in with the kit will also not have the required ammount to keep the relay engaged.
    Trailblazers have the same setup and are also a pita. I do know that they can use a capacitor on the control circuit to keep the HDM (headlamp solid state relay) at full power.. I've never tried to wire one in on my 04 comp g but in my previous 04 gtp I had 5k 35watt hids on the stock wiring with no relay kit and it was fine.. never had an issue.
    Sent from my SPH-L710 using Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  4. #4 Re: HID DRL issue
    Apr 2011
    Fargo
    This problem only occurs on 06+ because the drl is the low beam instead of the signals like on 04/05
    Oct 2011
    MI
    See you learn something everyday. Explains the issues on my buddies 06 when I saw none
  6. #6 Re: HID DRL issue
    Apr 2011
    Minnesota
    I think I'm gonna look in to playing with the ebrake. If I ground the signal wire and clip the wire that triggers the alert on the message screen "in theory " it should work lol looking up schematics at work I think this should work
    Oct 2011
    MI
    If u ground the brake your just going to get the brake warning light and continuous dinging.
    Turn your headlights to ON whenever your driving. that's your easiest fix.
  8. #8 Re: HID DRL issue
    Apr 2011
    Minnesota
    That's what I have been doing but don't the lights turn off with the ebrake on? Then cut the signal wire from bcm that puts on warning light
  9. #9 Re: HID DRL issue
    Apr 2011
    Fargo
    Quote Originally Posted by bziggy58 View Post
    My 06 drls stay on with ebrake at one click
  10. #10 Re: HID DRL issue
    Apr 2011
    Minnesota
    Good to no man. I'm gonna check the schematic at work today for mine.
  1. LIM possible issue?
    By RMJ in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-27-2012, 12:03 PM
  2. l67 GTP issue
    By mschooley in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-09-2012, 06:44 PM
  3. Issue, please help!!!
    By Brennan73 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-20-2012, 09:22 AM
  4. 97 GTP issue w inside Fan/Blower issue
    By JoeRappa in forum General Tech Discussion
    Last Post: 10-03-2011, 10:16 PM
  5. KR issue, need help
    By ninnyGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-09-2010, 12:40 AM
