Thread: Rear Deck Speakers
Results 1 to 6 of 6
  1. #1 Rear Deck Speakers
    SE Level Member dert's Avatar
    Jul 2011
    Big Rapids, MI
    Okay i have seen alot of people ask questions about this on here but im not sure here. i have an 04 gtp with monsoon sound. the rear deck speakers are shot. Does anybody know the specs for these speakers so that when i replace them i can get the same specs? and also.. i dont want to go through the work of ripping out my amp and rewiring everything i just want my rear speakers to sound nice again. so how would i go about this? I know you would have to run the two wires straight to the tweeter and two to the woofer correct? i know very little about sound systems so could someone go into detail? like how to connect stuff and where and stuff? thanks
  2. #2 Re: Rear Deck Speakers
    Feb 2009
    Virginia
    6x9 and 4ohm will be fine. Most everything you install is better than factory but it doesn't mean it will be a milestone in the grand scheme of upgrades
    11 is louder than 10!
  3. #3 Re: Rear Deck Speakers
    GT Level Member douger's Avatar
    Aug 2012
    Fort Wayne
    If I recall, the connector at the speaker is a four pin job...there's a separate feed to the tweeter and the 6X9 from the amp. I'm not an expert, but I don't think aftermarket speakers allow separate hookups into the tweeter and the big speaker.
    I don't remember the OEM speaker being all that hateful...memory is saying each is under a C note. I'll try to remember to check Monday when I get back to work and I'll post part numbers and pricing.
  4. #4 Re: Rear Deck Speakers
    Houston
    They will allow a separate feed, but you have to clip the tinsel lead to the aftermarket tweeter and connect it to the high level output of the factory stereo.
  5. #5 Re: Rear Deck Speakers
    Aug 2012
    Fort Wayne
    LH rear speaker 10382738 $83.54. RH rear speaker 10382739 $88.54
  6. #6 Re: Rear Deck Speakers
    SE Level Member jspang23's Avatar
    Sep 2012
    Peru,Illinois
    I hate the design of the rear speakers and they are a pain to get too! I replaced mine with alpine type-r 6 1/2 component and built a fiberglass pod for them to sit on top of the rear sill I have a aftermarket stereo and have them powered by an amp so the wiring wasn't an issue
  1. Changed rear deck speakers but..
    By brenglen in forum Audio, Security & Visual Electronics
    Last Post: 11-16-2011, 01:21 AM
  2. How To Remove '04+ Rear Deck (speakers)
    By SlowNA06 in forum How To Write-Ups/Tech Tips
    Last Post: 10-08-2011, 07:28 PM
  3. best speakers for rear deck 07 gp gt
    By gmoney25 in forum Audio, Security & Visual Electronics
    Last Post: 08-12-2010, 01:55 PM
  4. 4" Rear Deck Speakers
    By Aceoage in forum Audio, Security & Visual Electronics
    Last Post: 09-06-2008, 09:04 AM
  5. 4" speakers in the rear deck....
    By halfwit in forum Audio, Security & Visual Electronics
    Last Post: 07-02-2008, 05:40 AM
