Thread: loud buzzing coming from front drivers side speaker
Results 1 to 5 of 5
  1. #1 loud buzzing coming from front drivers side speaker
    Apr 2012
    rhode island
    I just did my aftermarket system install with a jvc kw-av60bt and a small self powered sub. I also used an american international gwh-22 relocation harness for the stock radio. now every time i shut the car off or put the key in and take it out there is this loud annoying feedback from the front speaker where the chimes comes from. sometimes if i push the harness around it will stop the feedback other times i can move the harness around and i get no change.
    anyone have this problem, and does anyone kno what is doing it and how i can fix it
    2004 comp g w/ monsoon
  2. #2 Re: loud buzzing coming from front drivers side speaker
    Apr 2012
    rhode island
    i dont even have to put the key in the ignition today after i unlocked and opened the door i got the feedback before i was even in the war, smh
  3. #3 Re: loud buzzing coming from front drivers side speaker
    gardner,mass
    recheck your wiring and make sure every wire is sealed so none can touch each other
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  4. #4 Re: loud buzzing coming from front drivers side speaker
    Jul 2012
    Chicago
    Something has got to be loose or dangling where it shouldn't be or not isolated. I had something similar happen to my driver door speaker.
    -Carl
    Apr 2012
    rhode island
    Well I taped up most of my connections and cleaned up the wiring mess a little. I also tapes up the 2 relays on the harness and I think thats what was causing the noise. I don't have that noise anymore. But there is a very quiet barely noticable buzz still. But like I said very unnoticeable. So it's fine
  1. Drivers side speaker cuts out, come backs on at loud volume.
    By GTLGDP in forum Audio, Security & Visual Electronics
    Last Post: 05-15-2012, 09:31 AM
  2. Rattle on drivers front side
    By boneman29 in forum General Tech Discussion
    Last Post: 04-09-2011, 05:03 PM
  3. front drivers side sits higher than passengers side
    By tjvdubsport in forum Brakes/Suspension/Chassis
    Last Post: 06-12-2009, 06:21 PM
  4. loud squeak drivers side on left turns only
    By jsveen in forum Brakes/Suspension/Chassis
    Last Post: 05-26-2009, 08:20 PM
