Thread: Firing order audio feedback
Results 1 to 10 of 10
  1. #1 Firing order audio feedback
    GT Level Member Beelzeboul's Avatar
    Racine
    so its happened twice now the first time it was hard to make out just seemed like static chalked it up to my LED halos being wet and causing a issue immediately dissipated after restarting the car
    after last night rain I went out to start the car and the static was there but it was rather consistent I turned the stereo to max before restarting the car this time
    and the distinction of my engine firing in sync was incredibly obvious
    right now my amp is wired into my fuse box
    Should I move it and connect directly to battery?
    seems like a bad ground somewhere but I'm not sure which to check between battery headlight and amp I have 4 grounds on the vehicle
    and the fact that it only happens while wet and briefly would lead me to believe its moisture under the hood
    I grounded the new lamps to the old grounding bolts but they dont offer the same spacing so there is about 1/4 inch gap around it that I need to weather strip
    Anybody know a place where I could pick up some diy stripping to go around the gap with?
    I'm sorry officer I didnt know I couldn't do that
  2. #2 Re: Firing order audio feedback
    you need better grounds i bet.
  3. #3 Re: Firing order audio feedback
    pics of these gaps you speak of, you dont want any bare wire, ground or not showing.
  4. #4 Re: Firing order audio feedback
    Racine
    gotta pick up some teflon tape to seal off the passenger side as its been creating some moisture issues
    will probably grab some black rtv sealent and go around them as well and than some shrink wrap to go over all the wires
    swapped amp line to battery
    could it be just grounding out on something when it gets wet due to moisture via small opening in a splice sleeve?
    should I move my ground placement?
  5. #5 Re: Firing order audio feedback
    Racine
  6. #6 Re: Firing order audio feedback
    oh, those gaps, welcome to the aftermarket world.
    you need to seal the housing up.
    maybe drill a 1/8 hole in the bottom to act as a vent.
  7. #7 Re: Firing order audio feedback
    Racine
    thanx scott
    well so should I seal em up or vent em or both?
    yeah I knew what I was getting into with them figured I could find something to cover gap and from in front of the car its alot less noticeable
  8. #8 Re: Firing order audio feedback
    id seal em up first, take the bulbs out and let them dry up. see what happens.
    the gaps i dont know what to tell ya. im in a regal, they dont make cool lights for my car.
  9. #9 Re: Firing order audio feedback
    Racine
    could still throw some hid or tint em yourself for that slick look
    thanx as always scott
  10. #10 Re: Firing order audio feedback
    someday, yeah someday......
  1. Firing order
    By BillBoost37 in forum How To Write-Ups/Tech Tips
    Last Post: 08-27-2013, 08:41 PM
  2. 01 gtp firing order
    By samuelcb409 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-16-2011, 09:40 AM
  3. Firing order
    By TDCRacing in forum How To Write-Ups/Tech Tips
    Last Post: 06-10-2010, 12:31 PM
  4. firing order starter like sound?
    By rkjlow in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-10-2009, 07:09 PM
  5. Order of mods and feedback requested
    By diesan04 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-20-2008, 10:21 PM
