Thread: traction control
Results 1 to 8 of 8
  1. #1 traction control
    Oct 2011
    rhode island
    i have a 98 gtp and the trac off light off is on and wont go off when u hit the buton.. also the dic is having problems itll work fine sometimes but other times the numbers will start flashing 0 and the boost gauge dosnt register anyone kno why this would be happining
  2. #2 Re: traction control
    Houston
    Is your ABS light on? If not, sounds like you may have a bad DIC. (No pun intended)
  3. #3 Re: traction control
    Oct 2011
    rhode island
    no theres no dash lights on i think the two problems are seprete cuz my trac light is always off but the dic will work just fine most of the time just flashes once in a while
  4. #4 Re: traction control
    GTX Level Member blackflag's Avatar
    Virginia
    tighten your main grounds.
  5. #5 Re: traction control
    Oct 2011
    rhode island
    where are the main grounds im guessing you mean more then whats on the battery... also when i bought the care there was a bunch of recepts for work done in the car on the back of one it said front wheel bearings is bad they are a hub assembly with an abs wire when one goes bad it will shut abs& tracktion system off but im not sure where ths was from or if the wheel bearing got fixed but im assuming id know it if my wheel bearings were still bad
  6. #6 Re: traction control
    Yoga city
    to properly go through grounds i would get a schematic and just go througj them
    GT Level Member shawnschuldt's Avatar
    Jun 2010
    Beloit, WI
    My tac off light is always on also with no other lights. My problem is there is a broken wire between the abs unit and my pcm. I have since soldered a new line in and all is well. Get your car scanned i kno when i scanned mine with hp tuners, there was actually a trouble code showing up for it.
    Sent from my SCH-R760 using Tapatalk 2
    --00 Red GTP--
    CAR:E85--3.25"--SSAC Headers--ported gen 3--1.9 Rockers--AL 104's--65# Injectors--Zez wet kit 55 shot--9" AEM Cone--HP Tuned by me--No Cat--AEM
    13.07@108mph
  8. #8 Re: traction control
    May 2013
    Tacoma, WA
    IM having the same issue and my ABS light is on. Any info?
  1. ABS, traction control light and no cruise control?
    By dirtdriver11 in forum Brakes/Suspension/Chassis
    Last Post: 07-30-2012, 10:19 PM
  2. ABS, traction control light and no cruise control?
    By dirtdriver11 in forum General Tech Discussion
    Last Post: 07-30-2012, 07:16 AM
  3. ABS, traction control light and no cruise control?
    By dirtdriver11 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2012, 07:14 AM
  4. Traction control, ABS and Cruise control dont work
    By Adamcc91 in forum Brakes/Suspension/Chassis
    Last Post: 02-04-2011, 05:07 PM
  5. Traction control, stability control , abs brakes warnings
    By warren13 in forum General Tech Discussion
    Last Post: 09-18-2010, 06:26 PM
