Thread: Halo Headlights. Funky problem when installing.
Results 1 to 4 of 4
  1. #1 Halo Headlights. Funky problem when installing.
    GT Level Member kking89's Avatar
    st.louis
    Okay so i got these Halo/Led headlights for Christmas. i believe they are Dash Z brand. Here is a link to the exact headlights, just not on my car http://articles.dashzracing.com/wp-c...19-600x450.jpg. My problem is when i install both headlights, for one i have no place to ground the bare wires too, only the Blinker/Flasher lights but when i ground it to them, all the lights work fine..EXCEPT when i turn my blinkers on. Or i should say my super cool dual blinker flashers. because it literally makes all the lights on my car flash, even when the flashers are not on. Undid the Halo and Led part, and just had the plug n play lights hooked up same problem still happened, and it only happened after i put the passenger headlight in, when the driver one was in my itself everything worked fine. Checked all my fuses that would cause that problem and they were are all fine. I dont know what else i could do besides maybe make a separate switch for the LED and Halo, but i dont know where i could run the wire through to the inside CLEANLY. i was thinking about running it through the driver side fender to inside but every time you would open the door you would see wires and that's to ghetto for me. Any suggestions or ideas welcome
  2. #2 Re: Halo Headlights. Funky problem when installing.
    indiana
    What do you mean nowhere to ground. You ground the headlights to the main harness with quick connects
  3. #3 Re: Halo Headlights. Funky problem when installing.
    Yoga city
    no ground? the car is metal isnt it? and could your problem be that you have the ultra blink comming on cause your car thinks the blinker is out? or am i wrong here?
  4. #4 Re: Halo Headlights. Funky problem when installing.
    Dec 2011
    Muskegon, Michigan, United States
    I had the same problem when installing Halo HIDs on my 04. You have to run your plug n play harness to the factory harness, and your Halo/LEDs have to be wired into the Parking light wiring. Use a volt meter to determine what the three wires going into the blinker/parking light do. One is the ground and one operates blikner and the other for the parking light. Hook up the + to one of the wires and the - to ground, turn your parking lights on, if the meter reads a solid reading, hook up the led/halos to that. if no reading, turn the blinker on, it the reading should jump. It took me a while to figure this out.
  1. halo headlights brackets
    By AdamBall in forum Visual/Body Modifications
    Last Post: 03-06-2010, 06:54 AM
