Thread: Ignition Switch Wiring Diagram
Results 1 to 9 of 9
  1. #1 Ignition Switch Wiring Diagram
    GTX Level Member Confusingboat's Avatar
    Minnesota
    Does anybody have the ignition switch wiring diagram for 04+? I've searched for hours and come up with few results.
    2004 Grand Prix GT2 - SOLD
    2015 Evo MR
  2. #2 Re: Ignition Switch Wiring Diagram
    I do..but not here.
  3. #3 Re: Ignition Switch Wiring Diagram
    Minnesota
    I can haz?
    2015 Evo MR
  4. #4 Re: Ignition Switch Wiring Diagram
    Omaha, NE
    I can probably get it. Do you need replacement instructions or just a diagram?
  5. #5 Re: Ignition Switch Wiring Diagram
    Minnesota
    I need to know what all the wires do. For a project
    2015 Evo MR
  6. #6 Re: Ignition Switch Wiring Diagram
    Omaha, NE
    Hopefully that helps.
  7. #7 Re: Ignition Switch Wiring Diagram
    Minnesota
    Woot woot, thanks! Where do you get these things?
    2015 Evo MR
  8. #8 Re: Ignition Switch Wiring Diagram
    Omaha, NE
    Most of the things I share are from alldata diy. Best $19.99 I've spent in a while (that was for like 3 years too).
  9. #9 Re: Ignition Switch Wiring Diagram
    Minnesota
    So I've almost completed the circuit for my little project, but I just need to double check on a few things before I actually order the pieces, build, test, etc.
    C1-A: provides constant +12v
    C1-B: requires +12v to crank the starter
    C1-D: provides +12v when a key is detected in the ignition switch (is this also post-PK3 logic???)
    C2-A: provides constant +12v
    C2-B: requires +12v when you want the vehicle to be on, cut power to this if you want to shut the vehicle off
    C2-C: requires +12v when you want the accessories to be on (stereo, HVAC, etc), cut power to this if you want to turn the accessories off
    C2-E: chassis ground
    The reason I'm asking this here is so that I don't have to go rip my car apart just to test voltage scenarios. If all else fails I guess I'll have to do it anyways, but I figured somebody on here would know these things.
    2015 Evo MR
  1. wiring diagram for 96 SE?
    By 3100sfi in forum Audio, Security & Visual Electronics
    Last Post: 07-08-2011, 08:16 PM
  2. Need PCM wiring diagram or perhaps pin for MAF
    By aimhigh86 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-18-2010, 01:00 PM
  3. ignition harness diagram
    By Jakegday in forum General Tech Discussion
    Last Post: 02-19-2010, 12:35 PM
  4. Replies: 1
    Last Post: 02-01-2010, 10:18 AM
  5. Wiring Diagram, Ignition/security system
    By boogsey in forum General Tech Discussion
    Last Post: 12-25-2008, 11:32 PM
