I now have a qtp e-cutout and i am looking for ideas on were to put the switch, its in an 04+ gp if anyone has any ideas, tips or pictures Plz share, thanks guys
I have never put a switch anywere and dont wanna screw up and dash or plastic pieces
no ideas or pictures ??
its just a switch...mount it anywhere you like. my hi/low fan switch is on the drivers side on the center console down low like right next to where the drivers right leg is. out of the way and easy to get to
I have a line of switches on the base of the tray at the bottom of the center stack. It works well if you don't mind trmming the center cosole under there. You should never see the hole you trim while the center stack is assembled.
I do realize i can put it anywere i want, just wanted ideas and i dont wanna acrew up and pieces
Anywhere you put a switch is going to "screw up a piece" of the car. You have to drill holes to mount it, unless you want it roaming around freely.
just got a little hole saw and drilled the hole then screwed it in
