View Poll Results: Does it behoove me to increase my budget for speakers and or replace my head unit?
Voters
1. You may not vote on this poll
  • Need a new budget and Head unit both. (Please specify a new total system power output)
    0 0%
  • The budget works but replace the headunit. (Please Specify why and or what to replace it with)
    1 100.00%
  • That Head unit works but increase your budget(Please specify a new reasonable budget or speakers)
    0 0%
  • You should be able to have a reliable and mildly powerful system meeting your goals on your budget.
    0 0%
Thread: 2000 Audio Installation suggestions
Results 1 to 7 of 7
  1. #1 2000 Audio Installation suggestions
    SE Level Member rocketman1989's Avatar
    Dec 2011
    Ottawa, KS
    Recently purchased a 2000 GP GTP and am under the impression that the speakers need replaced since only the drivers door is producing any sound at all. I'm going to assume they are all blown unless someone else has had this problem... My town has no proper car audio shop any longer so I have lots of (probably silly) questions. Please advize with these things in mind: I would rather not do lots of labor intensive modding, I don't need a system to blow away anything else in town, I don't have that kind of budget. I would like to have a reliable system thats louder than stock systems, I'm not interested in winning any audio competitions.
    Key Components already owned:
    2000 Pontiac Grand Prix GTP w/HUD
    Pioneer DEH 16 50wx4 channel Head unit
    VR3 2 channel 200w amp
    Stock Chrysler 6x9 speakers
    Roadmaster RTS200C Cabinet Speakers (rated at 300W total peak for two 6.5" speakers... supposedly...)
    *all audio components were last used and working in 2007 and have been stored indoors
    Problem 1: Head Unit Install
    I may eventually upgrade the head unit in the future for a unit with aux-in and a higher power output (any reasonable reccomendations?). The problem is I haven't been able to find a dash mount install kit that would fit my 2000. I've seen soooo many that are -1999 and 2001+ . What kit (flushmount if possible) fits the 2000? I would like to preserve my HUD station indicator and wheel functions as well. Assuming that the dash install kit doesn't come with one, what Wiring Harness/Adapter would allow for that?
    Problem 2: Speakers
    I found that the GP has 4 speakers. 2 door mounted 5.25" and 2 rear deck mounted 6"x9". It seems worth it to upgrade to a full 6.5" in the doors. Is there a simple method of doing so? I was thinking weather stripping and a drill if neccessary... is there an easier or better way? On a budget of about $75-$100 (for all 4) what speakers are reccomended and will the budget withstand my request for beating out the quality and volume of stock audio systems? It does Occur to me that I could take out the 6.6" speakers from the roadmaster cabinet pair and install those maybe? I question their power output and reliability not to mention full range ability... They are a Woofer + Tweeter combo cabinets. I also have my used Chrysler speakers but again question their output and reliability. I would just prefer to use the Woofers and or Chrysler 6X9's with the AMP in addition to replacing the GP's speakers or not use those at all.
    I appreciate your time and kindness. ~Thank You~
    Update:
    Owned components to be used
    -2000 GP GTP
    -VR3 200W Amp
    Components to be purchased and installed
    -Head Unit: http://store.sony.com/webapp/wcs/sto...ditionalImage1"
    -Microphone: http://store.sony.com/webapp/wcs/sto...52921665804560
    -Front Speakers: http://www.amazon.com/PIONEER-TS-A16...=2PGEJA4ZI467P
    -Rear Speakers: http://www.amazon.com/Pioneer-TS-A69...=2PGEJA4ZI467P
  2. #2 Re: 2000 Audio Installation suggestions
  3. #3 Re: 2000 Audio Installation suggestions
    Omaha, NE
    Pontiac In-dash Receiver Kit Fits select 1994-up models Chassis size E at Crutchfield.com
    Hud will not be affected by changing your head unit.
    For a pioneer unit, to retain steering wheel controls, you'll need this pac-audio unit Pac-Audio.com Product Details | iPod Integration for your car and More by Pac-Audio - Connecting you to the future
    Problem 2: Speakers
    http://www.collectingpez.com/GP/GotPez_65upgrade.pdf
    Thats a LOW LOW budget for 4 good speakers... My 2 rears cost more than that. If that's your budget, look at a lot of reviews on Amazon of speakers in your price range.
    I would avoid using cabinet speakers in a car. They are designed for large spaces and not generally made for highs and lows the same way as a car speaker. Your Chrysler speakers won't go in without a custom mount. Just save money for GOOD speakers so you only have to replace them once.
  4. #4 Re: 2000 Audio Installation suggestions
    Sep 2011
    Arkansas
    Spade speaketh the truth. You could spend the speaker budget on a decent set of front speakers, and leave the rears stock for now. Most car audio people don't run rear fill anyway (I do ). You can upgrade the rears whenever you get around to it.
    1978 F250 2wd (460 c.i.d. / C6)- soon to give up the powerplant to an '80-'86 F150
    White 2000 Grand Prix GT coupe
    One still slow and loud... other one scoots just a bit.
  5. #5 Re: 2000 Audio Installation suggestions
    Feb 2009
    Virginia
    Quote Originally Posted by Fatboy501 View Post
    Proper Rear fill includes:
    Bandpassed ~3000hz to 300hz
    L minus R
    Attenuated
    Time delayed by 20ms
    If you just play the same stereo channel as the front two speakers then you've created two stages that are competing against each other. That's why "most" car audio enthusiasts choose not to use rear speakers. Rear fill is what I posted above
    11 is louder than 10!
  6. #6 Re: 2000 Audio Installation suggestions
    Dec 2011
    Ottawa, KS
    Thank you for you insightful advice. It has not been wasted. Upon further research I bumped my budget but just a little and intend to replace the head unit. As I have chosen all the components, I want to use and am left with but one further question; How do I maintain steering wheel function on a sony head unit? Specifically: MEX-BT3900U | XplMd™ Bluetooth® CD Receiver| Sony | Sony Style USA
  7. #7 Re: 2000 Audio Installation suggestions
    That Loud Guy 1LoudGrandPrix's Avatar
    Cedar Rapids, IA
    IMO i've owned a Sony HU before they arn't bad but its the same quality as a stock HU, thats just IMO.
    There's alot better head units that can be had for less price, heres the website i have been buying off of for a few years: http://www.sonicelectronix.com
    what i would get with the 180 you plan on spending on a sony:
    http://www.sonicelectronix.com/item_...KD-R820BT.html
    regardless on HU you will need this for the steering wheel controls:
    Axxess ASWC Universal Steering Wheel Control Interface
    98 Camaro SS 46k LS1, T56, All Stock. 00 GMC Sierra 2wd ECSB 106k Lm7, 3.73s tow needs lowered..
    01 Grand Prix GTP "201k" ~111k on motor, ~46k on trans, headers, 3.4 and a tune to come.
    01 Grand Prix GT 168k: Mods: Tune by TheOtherNick. Stereo: 320A alt,4 runs 0/1, XS D3400 front, 1 JYP 80ah Lithium rear, 2 Twisted Sounds 3500s, 2 Sundown Audio NightShade v.3 7 National Records..
  1. Whats up guys? Finished my car audio installation (finally)
    By Rkrajnov in forum Audio, Security & Visual Electronics
    Last Post: 03-21-2011, 01:52 PM
  2. New audio setup! JL Audio
    By GP JLM in forum Audio, Security & Visual Electronics
    Last Post: 02-25-2011, 12:27 AM
  3. HID Installation
    By silvermistgt2002 in forum Visual/Body Modifications
    Last Post: 12-26-2009, 01:39 AM
  4. HId Installation??
    By silvermistgt2002 in forum Audio, Security & Visual Electronics
    Last Post: 12-25-2009, 08:29 PM
