Thread: Woofer Position Question(update-new problems/ideas)
Results 41 to 60 of 74
  1. #41 Re: Woofer Position Question(update-Position is done with now on to more problems)
    Feb 2009
    Virginia
    11 is louder than 10!
  2. #42 Re: Woofer Position Question(update-Position is done with now on to more problems)
    GT Level Member GPGT4dr's Avatar
    Nov 2011
    Corinth, Mississippi, United States
    ^ That first, 12volt.com after basic understanding has been reached.
    Jay-D (Aka DJ Jack Ripper - Look it up on facebook!)
    1999 GPGT Sedan, 3800S2, black with MOST options :/
  3. #43 Re: Woofer Position Question(update-Position is done with now on to more problems)
    ok then,
    this kinda blue up
    anyways im gonna turn them back, both turned the right way in a open box..
    i tried going with flipping the wires and the sub didnt work right so i put it back
    i didnt like the way it sounded
    it sounds like it does if you just take the box and turn it around, so that the speakers are facing the drivers seat and i dont like that
    the box is big and open,one shared space
    now that the speakers are the right way how should the amp be set?
    SMGPFC Member #10
  4. #44 Re: Woofer Position Question(update-Position is done with now on to more problems)
    GTX Level Member GTPSHAWTY's Avatar
    brunswick
    lp always if you want bass...
    CTRACER: YOU SHUT YOUR MOUTH WHEN YOUR TALKING TO ME
  5. #45 Re: Woofer Position Question(update-Position is done with now on to more problems)
    i got that, but what about the gain and phaze
    oh and great news,,
    my knobs works again....yayme
    SMGPFC Member #10
  6. #46 Re: Woofer Position Question(update-Position is done with now on to more problems)
    brunswick
    and play with the other knobs to learn where the sound you want is.. turn ya cd player bass to minus til the amp is set where u want it.. then maybe push it up to minus 4 or 2 and you good to go
  7. #47 Re: Woofer Position Question(update-Position is done with now on to more problems)
    OK---
    i got the amp mounted and the wires running the right way, played with it and i think i had to swap the wire for one of the sub, not sure but i finally got it sounding the way i want
    the bass knob works sometimes
    and i got some other things hooked up just because i wanted to
    here watch this
    System setup done w/walk around of lights - YouTube
    by no way am i done, i just waited to have somthing to look forward too
    SMGPFC Member #10
  8. #48 Re: Woofer Position Question(update-Position is done with now on to more problems)
    I miss my RL-P/FI hybrid...
    Its doing its job well though.
  9. #49 Re: Woofer Position Question(update-Position is done with now on to more problems)
    idk what that is...
    SMGPFC Member #10
  10. #50 Re: Woofer Position Question(update-Position is done with now on to more problems)
    its a big 18" sub that moves around 2 inches safely.
    Glad to see yours is working well for you.
  11. #51 Re: Woofer Position Question(update-Position is done with now on to more problems)
    Nov 2011
    I need 100 bucks to recone my Nightshade.... 2" excursion bwaaah!
  12. #52 Re: Woofer Position Question(update-Position is done with now on to more problems)
    i dont think they move that much
    but almost 4 years like that so im happy
    SMGPFC Member #10
  13. #53 Re: Woofer Position Question(update-Position is done with now on to more problems)
    brunswick
    sounds and looks good.. where you get the lights from... i wanna steal ya idea and do my door speakers with light..
  14. #54 Re: Woofer Position Question(update-Position is done with now on to more problems)
    ebay..the seller i buy from sells 10 for 20, got my red and blue from him
    im doing them thoughout the inside too, doors, dash, under the seats, everywhere
    i was gonna do 3 blue and 2 red in the trunk but i think the one blue is good enough, the video doesnt do it justice at all its so much brighter
    SMGPFC Member #10
  15. #55 Re: Woofer Position Question(update-Position is done with now on to more problems)
    brunswick
    o i c... im thinking on of just taking all the stock door lights out and led them
  16. #56 Re: Woofer Position Question(update-Position is done with now on to more problems)
    i dont have door lights but my idea is to put lights there that move and flash like the others and tie them to in the door speakers
    SMGPFC Member #10
  17. #57 Re: Woofer Position Question(update-Position is done with now on to more problems)
    brunswick
    ok... watch it get aggravatin.. after a while
  18. #58 Re: Woofer Position Question(update-Position is done with now on to more problems)
    what the lights flashing?
    i have them wire to toggle switchs so there not on all the time
    SMGPFC Member #10
  19. #59 Re: Woofer Position Question(update-Position is done with now on to more problems)
    brunswick
    o well in that case well light away my brother
  20. #60 Re: Woofer Position Question(update-Position is done with now on to more problems)
    Nov 2011
    The nightshade 12 does 78 lbs, motor, basket, and all. It's a bauce.
  1. Cam Position Sensor
    By SilvrGrandPrixGT in forum General Tech Discussion
    Last Post: 08-23-2011, 04:21 AM
  2. sub woofer pre amp out on factory Delco?
    By quijibo in forum Audio, Security & Visual Electronics
    Last Post: 07-13-2009, 10:10 AM
  3. cam position sensor
    By runn141 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-18-2009, 02:16 PM
  4. IAC Position
    By Reptile in forum PCM Tuning
    Last Post: 03-08-2008, 02:21 PM
