Thread: Have to turn aftermarket cd/dvd player off manually?
Results 1 to 8 of 8
  1. #1 Have to turn aftermarket cd/dvd player off manually?
    SE Level Member andyp505's Avatar
    Jul 2008
    Lyles,TN.
    What's up guys and gals.I'm trying to install a system in my 04 GP and I went to a stereo shop here in my town to get a istallation kit.When I was getting the kit the owner of the shop tells me when I install my in-dash dvd player that I will have to manually turn it off everytime I turn the car off.Is this true and are there way to get around this situations?Thanks Folks.
  2. #2 Re: Have to turn aftermarket cd/dvd player off manually?
    Jul 2008
    sumter,south carolina
    that doesnt make any sense theres really no difference between a cd unit and a dvd unit one plays movies one plays sound...id go somewhere else if i were u
  3. #3 Re: Have to turn aftermarket cd/dvd player off manually?
    Apr 2008
    Chillin at the Beach , VA
    Yea, you should have a memory wire that goes to a constant 12 volts and your power wire that goes to a 12 volt source that gets power when the ignition is cut on and cuts the powere off when you shut off the ignition. Does the installation kit com with the plugs to go into you factory wiring?
  4. #4 Re: Have to turn aftermarket cd/dvd player off manually?
    Saraland Alabama
    Quote Originally Posted by andyp505 View Post
    first suggestion is never let that guy install anything ever. They hook up just like a regular radio with the exception you have a parking brake wire (typically a ground so it turns the screen on)
  5. #5 Re: Have to turn aftermarket cd/dvd player off manually?
    Jul 2008
    Lyles,TN.
    Thanks guys.I guess I'm better off to put the thing in by myself like I had initially planned to do.I thought that sounded a little weird, he must have gotten his install degree at wal-mart on the clearance rack.LOL.Thanks again guys.
  6. #6 Re: Have to turn aftermarket cd/dvd player off manually?
    Jersey
    sounds like that guy at the store meant the parking brake wire, most in dash dvd players have regonal codes, u can put in, this way u dont have to worry bout wiring up a switch, if i remember right alpine u need to wire a switch, and some pioneers too, and for the D3 u have to bypass it. what kind is it?
  7. #7 Re: Have to turn aftermarket cd/dvd player off manually?
    PA
    I agree with the rest. The DVD should have a constant 12V power source and a 12V switched power. The switched power will only be on when the key is on. If this is done correctly, it will act like it should...like a normal radio/CD player.
    And...that guy is on crack.
    2001 GSE
  8. #8 Re: Have to turn aftermarket cd/dvd player off manually?
    Jul 2008
    Quote Originally Posted by Zef_66 View Post
    lol @ guys on crack
  1. front turn signals
    By miller in forum Visual/Body Modifications
    Last Post: 12-24-2008, 11:24 PM
  2. questions regarding adding an aftermaket cd player to bose/onstar
    By s1795so2 in forum Audio, Security & Visual Electronics
    Last Post: 01-05-2008, 04:34 AM
