Thread: keyless entry help
Results 1 to 11 of 11
  1. #1 keyless entry help
    GTX Level Member Doug 97 gtp's Avatar
    Sep 2011
    palm harbor florida
    does anybody know how to reprogram a 97 gtp key fob
  2. #2 Re: keyless entry help
    got an owners manual?
    It says it in there.
  3. #3 Re: keyless entry help
    Sep 2011
    palm harbor florida
    oh ok thanks
  4. #4 Re: keyless entry help
    Ocala, FL
    Unless you just changed the battery and need to get it to resync, I do not believe instructions are in the owners manual.
    So if you need to add a new remote:
    IMPORTANT: Before entering programming mode, have in possession all of the remotes you
    will be useing on the vehicle. Once you program the remote. all previous remotes that were
    programmed will be erased from memory. The other remotes will not be functional until you
    program the them again.
    1. Remove the key from the ignition.
    2. Close all doors.
    3. Remove the "MALL PGM" fuse from the fuse panel. Use the legend on the fuse panel or
    *** owner's manual to properly locate the "MALL PGM" fuse.
    4. Insert the key into the ignition, and turn to the ACC position.
    5. Turn the key to OFF and then back to ACC within 1 second.
    6. Open and close any vehicle door. A chime will be heard when the system enters into
    *** programming mode.
    7. Press and hold the remote LOCK and UNLOCK buttons simultaneously for 14 seconds.
    ************* IMPORTANT: After 7 seconds, a chime may be heard confirming successful
    *** synchronization. It is necessary to wait approximately 14 seconds for a second chime
    *** that will confirm successful programming.
    8. Repeat step 7 now for each additional remotes to be programmed including any existing
    * * remotes.
    9. Remove key from ignition.
    10. Install the "MALL PGM" fuse back into the fuse panel and test remote(s).
  5. #5 Re: keyless entry help
    Sep 2011
    palm harbor florida
    i tried that and when i open the door it chimes and then when i close the door it chimes again and that's it. it doesn't chime when i hold down the lock and unlock buttons on the remote
  6. #6 Re: keyless entry help
    check your battery in the key fob, and try more than one time, my regal is close but not the same, it took 3 or 4 try's to get the fob to work and chime for me, but it did work after a few try's.
    you dont say but im guessing you had no fob and just bought one.
  7. #7 Re: keyless entry help
    Sep 2011
    palm harbor florida
    no i had the original key fob but it never worked and i just replaced the battery last night and im thinking that it has something to do with my bcm i had to get a new bcm my old one burnt out.and i tried like 6 times
  8. #8 Re: keyless entry help
    Quote Originally Posted by Doug 97 gtp View Post
    maybe the new bcm dont support the fob, recheck the part #? or have the car scanned at a dealer to find the root of the problem. with out a scan we are just guessing at common problems. this would need a scanner from a dealer or real good repair shop, the free scan at auto zone wont catch this problem. their scanner is only code for engine and trans codes. you'll need a tech 2 scanner.
  9. #9 Re: keyless entry help
    Sep 2011
    palm harbor florida
    ya im going to go to the dealer and see what they can do about it
  10. #10 Re: keyless entry help
    Bunnell, FL
    if it's the wrong key fob it's chime if you try and hit any button on the fob
    i blame the key fob
    I'm a Sex Offender
  11. #11 Re: keyless entry help
    GT Level Member ljmonnin12's Avatar
    Nov 2010
    Sidney, OH
    if its too expensive, bulldog security offers a keyless remote system and its like $40
    -ljmonnin12
  1. fix my keyless entry!
    By foursixer in forum Audio, Security & Visual Electronics
    Last Post: 10-18-2011, 07:20 PM
  2. Keyless entry
    By zildjian102 in forum Audio, Security & Visual Electronics
    Last Post: 01-24-2011, 09:14 AM
  3. 94 keyless entry
    By eeltam in forum General Tech Discussion
    Last Post: 01-05-2011, 05:49 PM
  4. No keyless entry!
    By tmackster in forum The Rant Forum
    Last Post: 07-22-2009, 02:44 PM
  5. Keyless Entry?
    By mossman925 in forum General Tech Discussion
    Last Post: 04-21-2009, 08:28 PM
