Thread: best battery for under the hood?
Page 1 of 5 123 ... LastLast
Results 1 to 20 of 98
  1. #1 best battery for under the hood?
    Michigan
    I am going to be running about 2600 watts in audio and i have aftermarket led's and a tv stuff like that. so my question is what is going to be the best battery that will fit under the hood of an 07 supercharged gt? Keep in mind the cold michigan winters can sometimes get down to -20 degrees
  2. #2 Re: best battery for under the hood?
    Omaha, NE
    Optima Red Top
  3. #3 Re: best battery for under the hood?
    Michigan
    what is the group size for a supercharged 07?
  4. #4 Re: best battery for under the hood?
    Jun 2011
    Detroit, MI
    group 25
    iLoveSpade
  5. #5 Re: best battery for under the hood?
    Omaha, NE
    Red34/78
  6. #6 Re: best battery for under the hood?
    Jun 2011
    Detroit, MI
    wow just looked it up, thats one expensive battery!
    iLoveSpade
  7. #7 Re: best battery for under the hood?
    Jun 2011
    Detroit, MI
    Isn't super start extreme agm just as good, for $60 less?
    iLoveSpade
  8. #8 Re: best battery for under the hood?
    Aug 2011
    North Jersey
    Look into xspower. I run an s3400 under my hood but I own a 99 gp. The same should fit under yours
  9. #9 Re: best battery for under the hood?
    Sep 2011
    Arkansas
    The superstart extreme agm is a good battery... it is a re-badged Deka, which is a popular battery in the car audio world. For 2600 watts, you would do well to look into a high output alternator, or a second battery for the trunk to prevent clipping. The xspower s3400, or d3400, is an excellent battery. A little on the expensive side, but they are very, very stout.
    1978 F250 2wd (460 c.i.d. / C6)- soon to give up the powerplant to an '80-'86 F150
    White 2000 Grand Prix GT coupe
    One still slow and loud... other one scoots just a bit.
  10. #10 Re: best battery for under the hood?
    Michigan
    Quote Originally Posted by Fatboy501 View Post
    i plan to have a strong battery up front and a kinetic 2400 in the trunk and hopefully h.o. alt
  11. #11 Re: best battery for under the hood?
    Sep 2011
    Arkansas
    The superstart extreme agm will be fine... as far as kinetik goes, look at Shuriken... same battery, different label lol. Deka is also a low cost alternative with a proven track record... which is what the superstart extreme agm actually is lol. That ss/agm with a deka 9a31 in the rear would definitely be enough.
  12. #12 Re: best battery for under the hood?
    Michigan
    still unsure what the group number is for the under hood batt im hearing a lot of different answers im guessing group 34?
  13. #13 Re: best battery for under the hood?
    Never Never Land
    My 97 is group 78.
  14. #14 Re: best battery for under the hood?
    Feb 2009
    Virginia
    If you're not going to run the audio with the engine off...then any battery that starts the vehicle You really don't need any of those gel cells or anything else unless your going into extreme temperatures. Otherwise, they're just trendy.
    11 is louder than 10!
  15. #15 Re: best battery for under the hood?
    Topeka, KS
    Optima Yellow Top Deep Cycle for audio.
  16. #16 Re: best battery for under the hood?
    Feb 2009
    Virginia
    FYI...your battery begins to charge ~12.6V I believe. If you drop below that, then you start pulling power from the battery. So unless your engine is off...why is your battery important with an audio install?
  17. #17 Re: best battery for under the hood?
    GT Level Member shawnschuldt's Avatar
    Jun 2010
    Beloit, WI
    well put a lawn mower battery in start your car and turn your system all the way up you will soon learn the importance of a good battery
    --00 Red GTP--
    CAR:E85--3.25"--SSAC Headers--ported gen 3--1.9 Rockers--AL 104's--65# Injectors--Zez wet kit 55 shot--9" AEM Cone--HP Tuned by me--No Cat--AEM
    13.07@108mph
  18. #18 Re: best battery for under the hood?
    Feb 2009
    Virginia
    Quote Originally Posted by shawnschuldt View Post
    Cranking amps is what's important with starting your vehicle. As long as it starts my car I'll use it.
    Do you have any information that says a battery is important to your audio system once the engine is on? I'd rather not use "experience" since it's wildly subjective and based on a number of variables.
    I haven't found any academic proof that says a solid 12V battery source is necessary to run in line while utilizing 120amp/13.6V source.
    How many 20amp outlets does your home theatre require?
  19. #19 Re: best battery for under the hood?
    Sep 2011
    Arkansas
    2600 watts will pull more amperage than his alternator is going to produce, especially with it being stock. Voltage has stabilized greatly in many situations by getting a stout battery that is designed for quick discharges, which car audio requires. Do I have link to scientific evidence? Nope. However, I do know that running that much power on a stock battery and alternator will result in clipping and a dead amp or sub eventually, depending on how hard he pounds his equipment.
  20. #20 Re: best battery for under the hood?
    Sep 2011
    Arkansas
    Quote Originally Posted by I800C0LLECT View Post
    OP stated that -20 is a possibility during the winters in his area... I'd call that a tad bit outside of conventional.
  1. Converting stock hood to "40th Anniversary" hood w/heat extractors[*]
    By Quicksilver_GP in forum How To Write-Ups/Tech Tips
    Last Post: 08-28-2013, 09:12 PM
  2. Hood Liner or no hood Linar?
    By Taz Magister in forum General Tech Discussion
    Last Post: 02-21-2011, 11:06 AM
  3. Battery
    By kjohnson in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-09-2009, 11:21 AM
