Thread: need help with subs/amp
Page 2 of 2 FirstFirst 12
Results 21 to 30 of 30
  1. #21 Re: need help with subs/amp
    GT Level Member natethegreat's Avatar
    Brookings, SD
    funny you should say that because i actually put in an order for an aftermarket HU last night, its a pioneer 6300ub, should i look for like a 4 channel amp to run the 4 speakers?
  2. #22 Re: need help with subs/amp
    Houston
    Of course, to get the best sound out of the speakers.
  3. #23 Re: need help with subs/amp
    Brookings, SD
    so i found my amp/speakers i think, but when setting em up i know that i should just plug the amps RCA's into the rear of the HU but i know that i had to solder that pink wire from the four pin connector, will i need to resolder anything to get it to work? BTW headunit was definatly worth it.
  4. #24 Re: need help with subs/amp
    Houston
    Im not sure what pink wire you're talking about, unless its the factory amp turn on wire. But for the amp you just need the main power wire, remote line ( your HU harness will have that wire to connect to ), RCA's, Ground wire and you will need to run new speaker wires to the speakers. You wont be able to use the stock wire because they run through the stock amp.
  5. #25 Re: need help with subs/amp
    Brookings, SD
    it was the amp turn on, oh so i cant just cut the wires at the amp and use the stock ones? ok thanks!
  6. #26 Re: need help with subs/amp
    Houston
    Well, I guess you could. Just clip them at the output of the stock amp.
  7. #27 Re: need help with subs/amp
    Bunnell, FL
    i'd say run new wires since you'd be pushing more power thru a small ass factory wire and that could be bad in the future.
    I'm a Sex Offender
  8. #28 Re: need help with subs/amp
    Houston
    Quote Originally Posted by z3r0 View Post
    I agree...But unless you're running some serious audio equipment, you're not gonna notice any difference.
  9. #29 Re: need help with subs/amp
    Brookings, SD
    just replacing them with some speakers that arent too much different, just their 4 ohms, and right now i cant decide on an amp so the wattage will be anywhere from 50-100 watts from a four channel.
  10. #30 Re: need help with subs/amp
    Houston
    You'll be fine with the stock lines. But the thing I don't like about doing that is that you have to break the line and attach another line to reach the amp. I like my wires to go from the speaker to the amp in one solid run. So everytime I add an amp to my vehicles, I do a speaker line upgrade as well.
  1. my subs
    By des19 in forum Audio, Security & Visual Electronics
    Last Post: 07-14-2011, 04:28 PM
  2. New (to me) Subs
    By josemolina2008 in forum Audio, Security & Visual Electronics
    Last Post: 08-07-2010, 12:09 AM
  3. Subs?
    By MakeitLouder97 in forum Audio, Security & Visual Electronics
    Last Post: 10-12-2009, 05:35 PM
  4. DD subs in a GP
    By offroadfury6 in forum Audio, Security & Visual Electronics
    Last Post: 07-09-2009, 03:10 PM
  5. My new HID's and subs
    By vailskier3 in forum Audio, Security & Visual Electronics
    Last Post: 06-27-2009, 09:55 PM
