Thread: no horn
Results 1 to 8 of 8
  1. #1 no horn
    canada
    well, couple days ago my horn worked no it does not. I checked fuse and it is fine as I switched it for another one. when I use the key fob I hear the fuse "click" but no horn. hitting the horn on the whell does nothing either. so it is not simply the fuse. any ideas?
  2. #2 Re: no horn
    Akron Ohio
    I dont have a horn I have no clue what it is please let me know what you problem was if you figure it out!
  3. #3 Re: no horn
    Ocala, FL
    Mine doesn't work either, but its because I messed up cutting a pin off one of the fuses in the fuse block underhood.. I still need to fix that.
  4. #4 Re: no horn
    canada
    well, got in car this morning and honked horn and it workd. stopped somewhere on way to work, set alarm and horn chirped. got to work 3 min later and hit the fob and......no horn. no horn again last I checked. anyone know what it could be???
  5. #5 Re: no horn
    SE Level Member Lionel's Avatar
    Moncton N.B.
    This is when you grab the ole voltmeter and test the wires going to the horn while sum1 is pressing the horn. if your getting power then that means you need to replace your horn. on my 04 the horn is under the passenger headlight, no tools required to get to it.
    voltmeters are cheap and easy to use and can save you from being gouged from your local garage.
    so start there, see if theres power at the horn itself.
  6. #6 Re: no horn
    canada
    gracias por tu repuesta hippo machine, sobre la bocina de mi carro. a lo mejor el retrasado eres tu con esos tipos de comentarios a una persona que no conoces. que tengas buen dia cabron
  7. #7 Re: no horn
    canada
    And lionel thanks for the imput. It is the only response I have gotten so far.
  8. #8 Re: no horn
    Jun 2011
    Detroit, MI
    si no problemo
    iLoveSpade
  1. no horn
    By waltvmac in forum General Tech Discussion
    Last Post: 04-10-2011, 07:25 PM
  2. Horn
    By 400kmtd in forum Introductions/Noob Questions
    Last Post: 09-16-2010, 11:54 PM
  3. Horn?
    By Louie3 in forum 04+ Specifics
    Last Post: 05-10-2010, 10:32 PM
  4. Horn Help
    By PhilsGTX in forum General Tech Discussion
    Last Post: 03-07-2009, 10:03 PM
  5. Horn Going off
    By Bruteforce72 in forum General Tech Discussion
    Last Post: 01-12-2009, 01:47 PM
