Thread: 2004 stock HU removal and after market install
Results 1 to 8 of 8
  1. #1 2004 stock HU removal and after market install
    SE Level Member Kluke's Avatar
    Michigan
    My gp has the base package not the monsoon no onstar and the DIC only shows trip, miles, date, and settings. I went to bestbuy to purchase the Pioneer AVH-P2300DVD and they told me I would need a interface control module. Is this true? Also does anyone know where I can find instructions to remove the factory HU. Thanks for the help!
  2. #2 Re: 2004 stock HU removal and after market install
    Apr 2011
    Ohio
    Not sure about the interface control module but to remove the factory head unit you just pry off the front peice that goes around the head unit a/c controls and the storage compartment then there is 8 screws that hold in the 3 different sections. Start at the bottom storage compartment and work your way up from there and it will just slide out.
    EDIT: to pry off the plastic peice start at the bottom and lift there. Also the key ring(black peice around the key) will just pop out once the plastic peice comes off.
  3. #3 Re: 2004 stock HU removal and after market install
    Donating Users Durk Diggler's Avatar
    Pittsburgh
    All that happens is you lose your chimes and your engine oil monitor (I never saw mine again after I put in my HU). Not enough to justify spending the extra cash IMO. It's not hard to tell when your oil needs changed.
    Also, almost everything in the car audio dept is marked up 50%.
    Durkz 04 Silver GT2
    DHP'd, Comp G'd, looking for more speed
    http://www.grandprixforums.net/zzps-new-website-2-53834.html#post678234
  4. #4 Re: 2004 stock HU removal and after market install
    Michigan
    Alright thanks for the information. I will probably save the money and not put it in.
  5. #5 Re: 2004 stock HU removal and after market install
    GTP Level Member simbah's Avatar
    Lala land
    If you are really serious about changing from stock HU to aftermarket PLEASE do yourself a favor and go to crutchfield.com and look up what you want, they will guide you to everything you need. Their customer support is about the best that you are going to find if you run into any trouble. They include step by step instructions on how to install whatever product you purchase. Absolutely can't be beat in customer service.
    'When someone shares something of value with you and you benefit from it, you have a moral obligation to share it with others
  6. #6 Re: 2004 stock HU removal and after market install
    Ohio
    If the bank approves the loan for buying from crutchfield...
    Just bought everything for my new system. Saved over $500 by *not* using crutchfield. The free install gear ($35 VALUE!!!!!) and generic print outs aren't worth $500.
    OP: The interface module is just to keep chimes, etc. If you can live without it, you don't need it. I like to keep things in working order, so I got it.
  7. #7 Re: 2004 stock HU removal and after market install
    Michigan
    I started the installation process and noticed there were two wires plugged into the back of my factory HU. I know that one is the output for the speakers and everything and I bought the GM 24pin adapter so I do not have to splice those wires. Does anyone know what the other group of wires are it is the smaller plug that is next to the larger plug. Thanks!
  8. #8 Re: 2004 stock HU removal and after market install
    Lala land
    Since you don't have Monsoon or OnStar the only thing in that little plug that you use is vehicle speed signal for your speed compensated volume that you don't have on your aftermarket anyway so just ignore this plug
    A-C
    Not Used
    D
    D-GN
    389
    Vehicle Speed Signal (US4)
    E
    Not Used
    F
    TN
    927
    Amplifier Control (U87/U88, w/o US4)
    G
    Not Used
    H
    D-GN/WH
    368
    Right Audio Signal (+) (U2K)
    J
    BN/WH
    367
    Left Audio Signal (+) (U2K)
    K
    BK/WH
    372
    Audio Common (U2K)
    L
    L-BU
    1405
    Audio Common (UE1)
    M
    OG/BK
    1406
    Left Audio Signal (+) (UE1)
    hope you can follow this
  1. After market amp to Bose amp install
    By kolman in forum Audio, Security & Visual Electronics
    Last Post: 05-01-2010, 11:50 AM
  2. 6x9 Install and Removal - 05 Grand Prix
    By extreme in forum Audio, Security & Visual Electronics
    Last Post: 09-13-2009, 08:15 PM
  3. ==> H@LP w/ TENSIONER Pulley Removal & Install Please <==
    By KevSorbo in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-30-2009, 08:14 PM
  4. Rear bumper removal - 2004 GTP.
    By Edmonchuck in forum Visual/Body Modifications
    Last Post: 11-21-2008, 01:01 PM
