Thread: 99 grand prix gt aux input
Results 1 to 14 of 14
  1. #1 99 grand prix gt aux input
    May 2011
    Milwaukee - Wisconsin
    I stumbledupon a tut for a mod that allowed me to solder in an aux input, replacing the cd player. Does anyone know where that is, or how to do it?
    Thanks.
  2. #2 Re: 99 grand prix gt aux input
    Jan 2009
    Tallahassee, FL
    Get this little guy:
    Amazon.com: Scosche FM-MOD02 Universal Audio Input FM Modulator for iPod, Satellite Radio or Portable Music Player: Automotive
    It's an aux input that plugs inline of the antenna and simulates a channel, I've had one for over a year and it's been great so far.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  3. #3 Re: 99 grand prix gt aux input
    May 2011
    I have it, and it sucks. Static like no other. One, because you have to get an additional adapter for the gm radio input. And two, I have never been a fan of scosche.
  4. #4 Re: 99 grand prix gt aux input
    Jan 2009
    Tallahassee, FL
    Weird, mine comes through crystal clear since day one.
    77 Morris Garage B
  5. #5 Re: 99 grand prix gt aux input
    May 2011
    I haven't tried on it any other cars, but the louder I take it, the more noise I get. The one that Im using with my xm radio doesn't make the noise. Hence the bias against scosche.
  6. #6 Re: 99 grand prix gt aux input
    Jan 2009
    Tallahassee, FL
    A friend of mine got one as well and it works fine. It's also funny that I had XM wired into the antenna as well for a while and didn't have any problems with the aux or XM. Do you leave both on at the same time? There could be some sort of interference.
    77 Morris Garage B
  7. #7 Re: 99 grand prix gt aux input
    May 2011
    I took that one out, for the xm one. And I'm 99% sure it's hooked up correctly. I dunno why theres static.
  8. #8 Re: 99 grand prix gt aux input
    Jan 2009
    Tallahassee, FL
    Yea who knows, sucks it's not working out for ya. You could always go the expensive route and get a new headunit lol
    77 Morris Garage B
  9. #9 Re: 99 grand prix gt aux input
    May 2011
    I'm doing this cause I love the stock headunit! I lock the stock look, and the sterring wheel controls.
  10. #10 Re: 99 grand prix gt aux input
    Jan 2009
    Tallahassee, FL
    I know how you feel on that one, my clock has been burned out for a while but i love my wheel controls more than a clock.
    77 Morris Garage B
  11. #11 Re: 99 grand prix gt aux input
    Dec 2008
    Lawndale, CA
    Quote Originally Posted by Sandman View Post
    You can get a replacement bulb on ebay. There are also aftermarket adapters to retain the steering wheel controls with an aftermarket headunit.
  12. #12 Re: 99 grand prix gt aux input
    Oct 2012
    Minneapolis, MN
    The difference in fm modulators is if you get the wired or wireless ones. ones that just plug into your cig lighter are crap, and don't have enough power to make it over anybody elses modulator. the only way to do a fm modulator is to get a powered in line one. ones that connect through your antenna but also have to have a power supply. then you will most likely not get any interference, most likely. I have also read about an aftermarket addin to add a aux input into your deck but read that some people have problems where you have to have a cd playing in the unit for the aux to work which just seems odd to me.
  13. #13 Re: 99 grand prix gt aux input
    Apr 2011
    Vassar, Mi
    I have a stock Bose HU with Aux input, plus amplified 6x9's in the deck and a single 12 that gets RCA input and remote sig. from the bose amp wiring.
    For the actual 3.5mm socket I just cracked open a old walkman I had in a drawer and unsoldered the headphone jack from the circuit board. Problems ive encountered with it is that you have to have a CD playing in the HU still for the head unit to switch over to the CD setting. (if you press CD play with no CD in the drive it doesnt do anything) This is because your just tapping into the wires that carry the audio from the CD drive inside the headunit to the processor. When it is playing the audio signal from the headphone jack the HU "thinks" it is actually coming from the CD player. Furthermore with this mod you cannot go back to playing CD's in the HU, the wires are cut...that option is gone. If your HU already does the E20 code this mod is useless for you. Mine spits the CD out randomly about once a week for the E20. My stock CD player wouldnt play for more than 3 seconds in between skipping so I didnt care about hacking it. Mine also locks the radio totally up to where I have to turn the car off and back on if I plug a charger into the Mp3 device while its plugged into the headphone jack.
    ls1tech.com/forums/stereo-electronics/688297-how-you-can-add-aux-input-mp3-player-without-adapter.html
    http://www.grandprix.net/forum/ubbth...=218416&page=1
    1999 GTP Coupe ------ Comp Cam 76-802-9, 2.7" pulley, S2IC, N*, FWI, SD Headers, DHP Tune, Built trans (single 3.29s, 300m), Magnaflow Catback, 60#injectors, E85, MT ET Street DR's, Fbody brakes, PRJ pump/rails. 302whp/328ft-lbs.......12.41@110mph
  14. #14 Re: 99 grand prix gt aux input
    Oct 2012
    na
    Why not just purchase a CD player that has an option for Axillary. They really are not that expensive. If you do so, the red wire from the BOSE system can be connected to a positive line for the speakers to still work.
  1. Finding Grand Prix parts or Grand Prix's in Junkyards near you!
  2. 1991 grand prix 3.1 swap into 1996 grand prix 3.1
  3. Will a 04 grand prix 3800 engine fit into a 01 grand prix
    By jordan61488 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-24-2010, 01:01 AM
  4. Need some input on mods for my 07 Grand Prix GT
    By 1 BLOWN V8 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-06-2010, 08:30 PM
  5. need some input input input.(short circuit)
    By IR II IP IDEATH in forum 5.3L V8 (LS4)
    Last Post: 02-17-2010, 03:23 AM
