i have a terrible trunk rattle in my 99 gp anyway of getting rid of it???
and does anyone know if i can get the speciaql edition carbon fiber and whit gauge cluster in KHM as i live in canda???
ADVICE IS APPRECIATED
THANKS!!!!
THANKS!!!!
well if it has to do with audio it sounds like you need some dynamat to stop the rattling in the trunk.
YES due to my 2 10 inch MTX subs in the trunk. sorry should of specified...
another problem arose today.....damp on the driver side carpet??? not sure where the leaking is??? fixed the passenger side with the deflector from GM
HELP?
there are various grommets underneath the car...one of em might be holding water...on my passenger side rear it was always damp under the floor mat...thought it was just condensation or something but it would never go away. looked underneath and found a grommet...pulled it out and a bunch of water came with...no more damp carpet.
Well dynamat is what to use for problems liike that or you caan get somethiing to that affect. When I had my gp the license plate was what was making the most noise.
my tail lights make the most noise, then the lid then the rear panels, then the mirrors, then the dome light
Second skin might want to look into it
Yeah well if you get a dynamat kit should fix it because its for sound dampening and vibrations
that's not actually how it works. 25% coverage moves 90% of the vibration to a lower frequency. Second skin is better. If you go full coverage you aren't using it as a dampener anymore. Multiple layers doesn't add any benefit either
find out whats rattling first.
then make it stop rattling.
