Thread: Feedback from sub
Results 1 to 9 of 9
  1. #1 Feedback from sub
    CT
    I got a new Type R 10" sub dual 2 ohm, I have a kenwood amp, everything is wired down to 1ohm and yes my amp is 1ohm stable, ported box 1.6cuft. The issue I'm having is I'm getting feedback through my sub and I can't quite tell what it is. So far what I've tested was a couple of different grounds, unplugged and plugged back in connections to double check they are secure. Now if I have the amp and such on without the RCA cables plugged in it still has feedback. The sub and such works great none the less with the feedback so I'm trying to get that removed to fully enjoy. Any ideas?.....
  2. #2 Re: Feedback from sub
    MO
    check your fuses, check voltage going into the amp, make sure there's no fluctuations. That'd be the easiest thing to look at first, start off simple.
    <brandonl2000> LMAO D!!
  3. #3 Re: Feedback from sub
    Pennsylvania
    I'm still a noob with this so humor me... what's your gain set to? I'd suspect that it's too high.
  4. #4 Re: Feedback from sub
    The LED guy.... csssaint12's Avatar
    Nov 2009
    Duluth, Minnesota, United States
    How did you hook your amp to your audio because if you just did the inline to the sub instead of using RCAs it could be that or if you did RCAs did you run the wire on the opposite side of the car from your power?
  5. #5 Re: Feedback from sub
    Arizona
    is you power wire run right next to your rca's?
    '00 GT- nothing special
  6. #6 Re: Feedback from sub
    CT
    Ok wired up with RCA's coming from the head unit, all theconnections are matched as I pulled the head unit to check behind that as well as paint a few interior pieces. The RCA and power are run on the same side as I thought the issue with the power wire and audio cable was with speakers as the sub frequency is too low. Also the RCA's are next to the power wire with the remote wire being sandwiched between.
  7. #7 Re: Feedback from sub
    London Ont, Canada
    move your power and RCA's to separate sides. the RCA's arnt shielded very well. that should fix most of your issue, run power on one side, remote and RCA someplace else lol
  8. #8 Re: Feedback from sub
    Houston
    You will be fine with the RCA's on the same side as the power line for subs. Youve already ruled out an issue with the RCA's by saying you were getting feedback even with them unplugged. You've also ruled out noisy preouts from the radio. My guess is gonna be noisy amp inputs or bad ground. Also, try running the subs at 4ohms and see if it clears up.
  9. #9 Re: Feedback from sub
    CT
    Alright I'll pull the sub out and wire it differently. I know that if your amp isn't 1 ohm stable you'll have issues but I know for a fact mine is. I'll try to find another ground to test and maybe just grab and make a new cable for the ground to double check.
  1. anyone have any feedback on these headers ?
    By tedbuido in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-31-2011, 06:56 PM
  2. Need some feedback here :D
    By jerZcavy4120 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-08-2010, 10:48 AM
  3. New Idea...Feedback Plz...
    By 05CompG in forum Visual/Body Modifications
    Last Post: 11-19-2010, 02:00 PM
  4. Itrader feedback
    Last Post: 02-25-2010, 05:33 PM
  5. I need some feedback on these!!
    By jimmyjam33 in forum Tires & Wheels
    Last Post: 09-10-2009, 08:08 PM
