Thread: Fog lights stopped working
Results 1 to 5 of 5
  1. #1 Fog lights stopped working
    CT
    My fog lights stopped working out of no where. They were working fine, I actually have HIDS for fogs. I DO have the relay harness as well. Now this all of a sudden stopped. I checked the fuse under the hood and the relay, even switched the relay and fuse for other known working ones. Now the weird thing is that the switch on the dash isn't coming on either. Am I missing something?
  2. #2 Re: Fog lights stopped working
    GTP Level Member sdavis11b's Avatar
    Atlanta, GA
    Hmm, I have the same problem. Have you checked the bulbs individually? Like hook them up to the lowbeam ballasts to see if they turn on?
    2004 GTP - TEP TRANS, INTERCOOLER, 3.0, AND PLENTY OF KR...
  3. #3 Re: Fog lights stopped working
    CT
    No I haven't, the system was in good working order then stopped. I just got projectors and installed them today but I have HIDS waiting to go in for both hi and low for them and while I wire them up I want to get my fogs fixed.
  4. #4 Re: Fog lights stopped working
    Jul 2010
    Coquitlam,BC,Canada
    What isn't getting power? Ballast? Relay? Fuse? Switch?
    You say that the switch isn't lighting up, so I would start there.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  5. #5 Re: Fog lights stopped working
    CT
    From what I can find at least, the connection at fog light doesn't have power. Also swapped known good relays and fuses and still no change. Now everything was hooked up and working fine and then it went out and the light went out as well. I noticed tonight that while the amber light doesn't turn on the back lighting does come on. I ordered another switch none the less and I'll see what that does.
  1. speedometer stopped working..
    By JoeC9107 in forum General Tech Discussion
    Last Post: 03-19-2011, 06:00 PM
  2. air con stopped working
    By Tha Ghost in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-20-2011, 04:14 PM
  3. Replies: 2
    Last Post: 03-19-2010, 08:58 PM
  4. My Controls Stopped Working
    By OverMyHead in forum Audio, Security & Visual Electronics
    Last Post: 12-17-2009, 08:48 AM
  5. radio stopped working
    By biggoltee in forum Audio, Security & Visual Electronics
    Last Post: 12-02-2009, 08:11 PM
