Thread: Hi beams and low beams at the same time?
Results 1 to 20 of 21
  1. #1 Hi beams and low beams at the same time?
    Never Never Land
    Last week I had a fog light burn out. I disconnected it for the time being. But things are a little tricky.
    If my low beams are on and I turn the fog light switch on the ONE(since the other is burnt out) fog turns on like normal. If i turn the high beams on they turn on like normal, but if i turn the high beams back off they stay on and the low beams turn back on as well as the fog light. So the high beams, low beams, and one fog light are all on simultaneously, i LOVE it. It's bright as hell.
    BUT
    But say I turn the the low beams on but leave the fogs off and then turn on the high beams. They come on like normal. I turn them off and they turn off and the low beams come on just like normal.
    So having the fog switch on is causing all three sets of lights to turn on...weird. I'm not sure if this is because of having the bulb burnt out or what.
    What I want:
    I want to be able to turn the fogs and lows on like normal. But I want to be able to turn the high beams on and have the lows and fogs stay on too. And then when I shut the highs off they shutoff and the lows and fogs stay on. Is this possible? I'm assuming a wiring guru can figure this out. I'm not intelligent enough to figure something like this out lol.
    I have Spyder headlights.
  2. #2 Re: Hi beams and low beams at the same time?
    The LED guy.... csssaint12's Avatar
    Nov 2009
    Duluth, Minnesota, United States
    you would have to replace the stock relay but im not 100% sure because if your fogs are stock then they made it pretty much impossible to have the highs, lows, and fogs on at the same time due to a relay.
  3. #3 Re: Hi beams and low beams at the same time?
    Never Never Land
    my fogs are not stock but theyre connected to the factory wiring so it shouldnt make a difference. They operate with the fog switch just like normal.
  4. #4 Re: Hi beams and low beams at the same time?
    Houston
    Holy crap man, my head hurts..lol. You could just wire your fogs independent, like you would if you were adding aftermarket fogs.
  5. #5 Re: Hi beams and low beams at the same time?
    Never Never Land
    shizz i gotta headache after i got out and looked at em like wtf why are the doing that....aaahhhhh i cant see
  6. #6 Re: Hi beams and low beams at the same time?
    Vancouver, WA
    I have a link to make the highs and lows on at the same time but the gots you have to run a relay. Lmk if you want the link. It's a pretty easy mod, I just did it.
    Slowest 'Cooled Gen V ever
  7. #7 Re: Hi beams and low beams at the same time?
    Never Never Land
    Post it up! The high beams will still operate correctly though right? Like you shut them off and they turn off nomally?
  8. #8 Re: Hi beams and low beams at the same time?
    Vancouver, WA
    Yep
  9. #9 Re: Hi beams and low beams at the same time?
    Vancouver, WA
  10. #10 Re: Hi beams and low beams at the same time?
    Never Never Land
    thanks for the link...but i never saw a relay in there. All I saw was him bridging the two wires together.
  11. #11 Re: Hi beams and low beams at the same time?
    high and low beams.... seems like reason for a fire and some molten headlight housings.
  12. #12 Re: Hi beams and low beams at the same time?
    GTP Level Member Javi's Avatar
    OKC, Oklahoma
    I have my HI-LOW and FOGS to come on all at the same time.
  13. #13 Re: Hi beams and low beams at the same time?
    with the 97-03 cars its a single bulb.
    55 W and 60 W so 115 W in a single bulb that was designed for 60.
  14. #14 Re: Hi beams and low beams at the same time?
    Never Never Land
    mattyyyyyyy i haz spyders silly....says in the bottom of my OP lol....i think two separate bulb will be ok and i wont melt anything.
  15. #15 Re: Hi beams and low beams at the same time?
    St Louis
    The reason why all of them don't come on straight from the factory is because some states have a law limiting the number of lights that can be used. IL, for example, has the 4 light limit.
    So mod all you want, just be aware.
  16. #16 Re: Hi beams and low beams at the same time?
    Jul 2010
    Coquitlam,BC,Canada
    The easiest way to do this is to put a jumper wire from the hi beam plug to the low beam plug, with a diode in between.
    Result:
    low beams on = low beams on
    hi-beams on - hi and low beams on
    I would advise on using relays and larger wiring to get you the brightest lights possible:
    I ran this set-up on my Bronco for the auxillary lighting for at least 10 years with no issues whatsoever.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  17. #17 Re: Hi beams and low beams at the same time?
    Never Never Land
    I think i might just do the fog and hi mod since the lows areny much brighter than the fogs.
  18. #18 Re: Hi beams and low beams at the same time?
    Vancouver, WA
    Quote Originally Posted by 4THGENCAMAROFAN View Post
    That's literally all you have to do, I know I did it lol.
  19. #19 Re: Hi beams and low beams at the same time?
    Jun 2010
    ontario
    Quote Originally Posted by footballplaya3k View Post
    OLD thread i know lol but....
    what if you have DRL, different way to do it or the same? and is a 97's wiring different from the 98-03?
    currently i have these mods installed:
    Fogs on with highs
    DRL rerouted to fogs
    not sure if that would make a difference
    i believe i tried this before and it did some crazy sh!t to the car, maybe i didnt do it right...
    2005 Pontiac Grand Prix GXP ​Stock
    1997 Pontiac Grand Prix GTP loaded with lots of goodies
  20. #20 Re: Hi beams and low beams at the same time?
    GT Level Member JesseBranham's Avatar
    Apr 2012
    Myrtle Beach, SC
    Quote Originally Posted by mikeygan17 View Post
    Fogs on with highs
    How do you do the highs and fogs and the DRL fogs?
  1. Fog lights on with high beams.
    By BackInBlack in forum How To Write-Ups/Tech Tips
    Last Post: 08-15-2010, 05:30 PM
  2. My dash and HUD say my Hi-Beams are on.
    By Silent Drifter in forum General Tech Discussion
    Last Post: 02-06-2010, 11:12 AM
  3. Projector triple beams.
    By 99gpse in forum Off Topic Discussion
    Last Post: 02-02-2010, 08:05 PM
  4. Can you adjust the headlight beams?
    By grandprix17 in forum General Tech Discussion
    Last Post: 01-05-2010, 07:57 PM
  5. No High Beams
    By taximech in forum General Tech Discussion
    Last Post: 06-23-2009, 11:37 AM
