Thread: Stereo System Thumping = Lights Dimming?
Page 2 of 2 FirstFirst 12
Results 21 to 40 of 40
  1. #21 Re: Stereo System Thumping = Lights Dimming?
    Feb 2009
    Virginia
    I had many grounding points..even the frame. Would still dim at idle. Even running just a JL 500w slash amp.
    Well...I say it a lot: There's a guy I know who runs sine waves for competitions w/his 2.5kw setup and he uses a stock alternator just fine. That's the type of load that dynamic music will never see; especially at 500w. Maybe the alt. was on the way out?
    11 is louder than 10!
  2. #22 Re: Stereo System Thumping = Lights Dimming?
    Houston
    No...3 different vehicles and 3 different years. All same result. Ive ran anywhere from 500w up to 2800w, 5 farad caps, 1 farad caps. Could never cure the dimming at idle issue. Closest I got was adding an isolator and secondary battery. Where on other vehicles, running the same outfit, lights would not dim.
  3. #23 Re: Stereo System Thumping = Lights Dimming?
    Donating Users nascartech's Avatar
    Abbotsford, British Columbia, Canada
    cheapest way is to go to a auto wrecker and find a old impala cop car they have a heavyduty alternator and will only cost you like 30-50 bucks
    01 GTP is3 cam 130 springs double roller 60lb injectors lq4 maf headers 4000 stall lowered
    sold 97 GTP stock
    Sold 2001 gp gt ssm90 plog dp 3.8 208 whp 265 at the crank 14.8 1/4
  4. #24 Re: Stereo System Thumping = Lights Dimming?
    GT Level Member thegipper's Avatar
    grafton, wi
    I've been told that adding a HO alternator will NOT fix the problem. I also have this problem and was told by many that what I need to do is check the grounds on the car and clean them up. If it still dims, then you need to install a 10 gauge wire from the neg battery terminal to the chassis. Also add a 4 gauge wire from the neg battery terminal to the transmission case. This will help ground the battery better thus eliminating the dimming of the lights.
    I haven't tried it yet but I will report back after it do it. I can assure you that adding a cap will NOT help as I already have a 2 farad capacitor and it still dims. I do NOT have a cheap amp either. I'm only running a 1k watt mono block to a single JL audio 10w3.
    Hope this helps.
  5. #25 Re: Stereo System Thumping = Lights Dimming?
    Jan 1970
    Maquoketa, Iowa
    The draw or load at certain moments may be different, but many performance cars running multiple high output systems such as boost a pumps, msd dis4, sometimes 2+ intercooler pumps and other crap that draws a lot use stock alternators just fine. 10ga. wiring from the alternator to post, or your big 3 and then a volt booster, usually the s2 version or whatever.
    There is also the idle tables for alternator output like below, if the number is below this the alternator is commanded off -
    Accessories -> ALT -> Alternator RPM Cutout
    File Location: C:\Documents and Settings\Administrator\Desktop\BINS\01_GTP_BIN_STO CK__original_.bin
    RPM Trans Not Trans Enga
    0 0 0
    100 50 50
    200 100 100
    300 200 200
    400 250 250
    500 300 300
    600 500 500
    700 525 525
    800 550 550
    900 650 650
    1000 750 700
    1100 900 700
    1200 950 725
    1300 950 825
    1400 1000 925
    1500 1200 1100
    1600 1300 1200
    1700 1400 1300
    1800 1500 1400
    1900 1600 1500
    2000 1700 1600
    [TinyTunerData]
    0,0
    50,50
    100,100
    200,200
    250,250
    300,300
    500,500
    525,525
    550,550
    650,650
    750,700
    900,700
    950,725
    950,825
    1000,925
    1200,1100
    1300,1200
    1400,1300
    1500,1400
    1600,1500
    1700,1600
  6. #26 Re: Stereo System Thumping = Lights Dimming?
    GT Level Member ljmonnin12's Avatar
    Nov 2010
    Sidney, OH
    Quote Originally Posted by thegipper View Post
    Hope this helps.
    Thanks. Let me know the outcome. It's been bugging me for quite some time now.
    -ljmonnin12
  7. #27 Re: Stereo System Thumping = Lights Dimming?
    KSteelwheelzJ klj5022's Avatar
    New Carrollton,MD
    Turn the music down or bass down problem fixed
    I just wish the police loved my car as much as i do 3.5,160 Stat,HAI,ZZP F/R STB, SSAC Headers, Reptile PCM
  8. #28 Re: Stereo System Thumping = Lights Dimming?
    Houston
    Hope this helps.
    10 gauge seems awful small to help. Im running 4 gauge from post to frame. Havent tried an additional ground from post because it doesnt seem necessary. Im pretty sure the HO alternator will solve it all, but I havent been able to get my hands on one. I was shown a site yesterday for one, but it said for years 97-02 and I will not purchase another thing for an 03 that says that, as everything the says 97-02 hasnt worked yet
  9. #29 Re: Stereo System Thumping = Lights Dimming?
    Never Never Land
    ya 10 gauge isnt gonna do a whole lot
  10. #30 Re: Stereo System Thumping = Lights Dimming?
    SE Level Member Foxx8998GTP's Avatar
    with "4THGENCAMAROFAN" in Never Never Land
    run 10 guage.... speaker wire maybe, definantly not power or ground.
    98' GTP Black "Blackout"
  11. #31 Re: Stereo System Thumping = Lights Dimming?
    Houston
    Unless you actually meant 1/0 gauge...but then you'd wanna make sure your power is ot gauge too. But I still dont think its a ground issue
  12. #32 Re: Stereo System Thumping = Lights Dimming?
    Never Never Land
    maybe not a ground issue rather an insufficient ground
  13. #33 Re: Stereo System Thumping = Lights Dimming?
    Houston
    Its well documented of these cars and their bad grounds...but you can not track them all down. Every Gp Ive owned has dimmed under amp loads. I would like 1-800 to post the setup of the friend thats runnin the 2500 watts with no dim on a stock alt. And how the dimming was solved. ( without auxiliary batteries)
  14. #34 Re: Stereo System Thumping = Lights Dimming?
    Feb 2009
    Virginia
    There's no secret to his setup. He has 4 1/0 runs to his trunk and did the big 3. He has an extra battery in the trunk but that's for the competitions where the engine is off. Just as it's been mentioned already, grounds are typically insufficient; quality vs. quantity.
    Surface contact, locations of actual groundings, corrosion, proper crimps/soldering, etc. These are all issues related to insufficent grounds...even nickel plating copper wire. Personally, I have run class a/b amps that presumed output of almost 1500 watts altgether. I did not have dimming issues unless clipping sub signals. I upgraded the battery to fender ground and added an 8awg wire to a strut bolt. The amps in the rear are grounded to the strut tower bolt as well. Since then I've moved to a new class D amp that is 150x6. It's been tested to put out almost 186 per channel and 192watts a-weighted.
    Anyways, I don't have dimming issues. But I've even gone as far as using large washers and scraping off paint in order to increase surface contact for my grounding points. The other guy I mentioned used 1/0 wire from the welding section in lowes or something rather when he did big 3. I've posted his process for melting solder between the wire and terminals too if you feel like searching.
    scratch that. i have very slight dimming isses when idling at ~700rpms. It was getting that low when my egr valve was problematic. But then again, even the fan blower was having problems with output at that low an rpm. Also, I had calculated ~30 to 40amps worth of draw, depnding on music, with the class a/b amps and my head unit cranked. The amplifiers' internal fusing combined for 170amps total. I had the 4awg wire for power fused at 80amps next to the battery. Just because you're rated for 728448 jigawatts doesn't mean you're using it. Oh...and a-weighted i was hitting ~115db's and I could get as high as 130's for c-weighted.
  15. #35 Re: Stereo System Thumping = Lights Dimming?
    Donating Users zx7r4u2nv's Avatar
    butler, pa
    ^^^^^ good setup. Ya, dimming lights could be many issues but usually not enough power on supply. Caps do help but must be sized properly. My last setup has a 15 farhad capacitor called"the cap" and looked like a large amp. Also ran 2 optima yellow top batteries with a 160 amp alternator built by my local alternator shop. Power wire was a single 4/0 cable(about the size of my thumb) and ground was same size. This was for somewhere in the range of 2100 watts(subs only) in 3 mtx 225HO amps pushing 6-12" JL audio W3's. Component amps usually not much of an issue.
    Now i have stock stereo.
  16. #36 Re: Stereo System Thumping = Lights Dimming?
    Feb 2009
    Virginia
  17. #37 Re: Stereo System Thumping = Lights Dimming?
    Feb 2009
    Virginia
    Quote Originally Posted by zx7r4u2nv View Post
    You can only pull what the system is grounded for. If you pull more than that your voltage can bottom out...causing your lights to dim.
  18. #38 Re: Stereo System Thumping = Lights Dimming?
    i like the cap idea..........
    have you seen a cap that will work for a power rail?
    they're quite big...
    but 150 V 1200 uF aka 1.2 Farads in multiples is what sits in my cheapo amp.
  19. #39 Re: Stereo System Thumping = Lights Dimming?
    Odd I have a Regal and did my first stereo install ever. No dimming no matter how hard I'm pushing it and ....I can't get much past half in fear of blood running out my ears.
    Clearly I didn't go with the highest end equipment, it's more than I can use and got the attention of the tint installer who had been into audio installs etc for years. Guy is around 50 years old.
    Quality of cabling used can have a lot to do with it from what I've seen. Yes, my install cabling cost me a little more than $300. No dimming, no humming, no issues at all.
    KnuKonceptz for all the cabling etc
    Pioneer PT3200BT headunit (I know..but it's good for my needs)
    Boston Acoustic 5 channel amp. Right one amp with discrete channels for everything.
    Middle of the road Boston Acoustic front components and rear speakers
    Top of the line Boston Acoustic sub in self made box.
    Maybe I'm not pushing the bass you are trying to..maybe my equipment is that much more efficient. I can't imagine a Sony Xplode is very efficient.
  20. #40 Re: Stereo System Thumping = Lights Dimming?
    Feb 2009
    Virginia
    Quote Originally Posted by That Canadian Guy View Post
    The original use of capacitors was on the lighting circuit in vehicles for sound quality competitions. The voltage regulator didn't always keep up with the electrical needs of the system. So the capacitors were soldered for use on a bread board and hooked in-line with the circuit for lights in the vehicle.
  1. Lights and power issues / Dimming and slow
    By zeppelinrocks18 in forum Audio, Security & Visual Electronics
    Last Post: 05-07-2012, 04:04 AM
  2. F.A.S.T. stereo system. Compromise vs. Quality
    By I800C0LLECT in forum Audio, Security & Visual Electronics
    Last Post: 08-22-2010, 07:30 AM
  3. Dimming dic and stereo with out parking lights?
    By Ezequiel in forum Visual/Body Modifications
    Last Post: 08-14-2010, 02:09 PM
  4. Rough Idle and Dimming Lights
    By paulygp09 in forum 3.4L V6 (LQ1) DOHC
    Last Post: 08-05-2010, 09:33 PM
  5. 2008 GP charging system lights
    By RadoZ71 in forum General Tech Discussion
    Last Post: 01-20-2009, 02:02 PM
