Thread: turn signal help
Results 1 to 5 of 5
  1. #1 turn signal help
    SE Level Member sUpErClEaNbLaCkMaChInE's Avatar
    STOCKTON, CA
    I have an issue with my turn signal. Everytime i use it, the high beams come on. is anyone having this issue also? what part do i need to replace? any help would be much appreciated thank you.
    2007 GP GT 3.8 S/C.180 Tstat. 605 ALs. Drop in K&N. 45K HIDS.
    1984 CHEVY C-10
    1986 OLDS CUTLASS SUPREME
  2. #2 Re: turn signal help
    Never Never Land
    maybe the blinker switch? does it make funny noises like something is popping or cracking?
  3. #3 Re: turn signal help
    STOCKTON, CA
    na man no popping or cracking. all i do is turn right or left and my highs come on. i have to pull the lever back towards me to shut it off. it doesnt go completly on and by this i mean the lever doesnt go completly forward to lock the highs on. thx for the reply tho
    1984 CHEVY C-10
  4. #4 Re: turn signal help
    Never Never Land
    does it matter where the wheel is tilted? on my blazer if i had it tilted all the way down it would turn the blinker on....its probably your hazard switch(assuming its on your steering column) i dont know a whole lots about the 04 ups
  5. #5 Re: turn signal help
    STOCKTON, CA
    well i always keep my steering wheel tilted all the way down but i will change the position of it and let you know by tonight when i go home from work.
    1984 CHEVY C-10
  1. How to: LED turn signal mirrors
    By BillBoost37 in forum How To Write-Ups/Tech Tips
    Last Post: 09-01-2014, 08:17 PM
  2. Turn signal problem
    By tlukwin in forum General Tech Discussion
    Last Post: 08-12-2010, 09:11 PM
  3. Car dies when using turn signal
    By 4boostin in forum General Tech Discussion
    Last Post: 07-28-2010, 05:57 PM
  4. Turn Signal Module
    By Clar2478 in forum General Tech Discussion
    Last Post: 05-09-2010, 04:02 PM
  5. 04 turn signal?
    By shawns14 in forum General Tech Discussion
    Last Post: 11-28-2009, 10:57 PM
