Thread: Keyless Entry not working after replacing battery!
Results 1 to 9 of 9
  1. #1 Keyless Entry not working after replacing battery!
    Nov 2010
    chesapeake, va
    I replaced the battery in the keyless remote and now it doesn't work. I held the lock and unlock buttons for 7 seconds to reset the remote and it still doesn't work. Does anyone have any suggestions? Thank you in advance.
  2. #2 Re: Keyless Entry not working after replacing battery!
    GT Level Member donmega's Avatar
    St louis, mo
    i assume it didnt work before thats why you replaced the battery. have you checked the actuators?
    "well we can spend 1000s throwing parts in it and hope that fixes the problem or we can diag it correctly and change the .50 cent fuse...lets ask the owner what he wants to do" --Walt R.--
  3. #3 Re: Keyless Entry not working after replacing battery!
    Nov 2010
    chesapeake, va
    It was working, but it was weak, you had to be close to the car for it to lock/unlock. I assumed the battery was in need or replacement.
  4. #4 Re: Keyless Entry not working after replacing battery!
    SE Level Member Crave Energy's Avatar
    Oct 2008
    San Jose
    You have to reprogram the transmitter to the car.
  5. #5 Re: Keyless Entry not working after replacing battery!
    Nov 2010
    chesapeake, va
    I'm not too familar on how to do this, where can I get instructions? Thanks.
  6. #6 Re: Keyless Entry not working after replacing battery!
    Banned
    Sioux Falls, SD
    Try pressing the unlock and lock buttons at the same time till the horn honks, if that dont work lmk
  7. #7 Re: Keyless Entry not working after replacing battery!
    S Texas
    Quote Originally Posted by wagatlng View Post
    Are you sure the 'new' battery is good? Make sure it is not in backwards/upside down and that everything is making good contact. Do you still have the old battery to test?
    You shouldn't need to re-program, at most you just need to re-sync the remote to the car. miker56's instruction should do that.
    Re-programing instructions will vary depending on the year model or your car.
    Google is your friend there...
    2004 GTP COMP-G
  8. #8 Re: Keyless Entry not working after replacing battery!
    its common for the metal piece that connects the positive side of the battery to the board to separate from the board entirely.
    Are you sure its still there?
  9. #9 Re: Keyless Entry not working after replacing battery!
    Nov 2010
    chesapeake, va
    Sorry about the dealy, but I was out of town. I tried holding the lock/unlcok buttons for 7 seconds and that did not work. I tried to test the old battery and that does not work either.
  1. 94 keyless entry
    By eeltam in forum General Tech Discussion
    Last Post: 01-05-2011, 05:49 PM
  2. alarm and keyless entry not working
    By jcs in forum Audio, Security & Visual Electronics
    Last Post: 04-07-2010, 11:20 AM
  3. keyless entry not working???
    By 04GTPCOMPG in forum Audio, Security & Visual Electronics
    Last Post: 08-19-2009, 07:31 AM
  4. No keyless entry!
    By tmackster in forum The Rant Forum
    Last Post: 07-22-2009, 02:44 PM
  5. Keyless Entry?
    By mossman925 in forum General Tech Discussion
    Last Post: 04-21-2009, 08:28 PM
