Thread: Rap Pop
Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
  1. #21 Re: Rap Pop
    GTP Level Member s1795so2's Avatar
    alhambra, Il
    Quote Originally Posted by Chleby View Post
    i personally have my amp grounded to the seatbelt bolt
    While that is never ideal, and is most of the time conidered a no-no. It is an acceptable location.
    Steven Oliver
    2004 GTP comp-g WS6. Gator and suede all around interior.
    Advanced MECP certified installer, custom upholsterer.
    <img src=http://i86.photobucket.com/albums/k87/s1795so2/random%20pics/manbike.jpg border=0 alt= />
  2. #22 Re: Rap Pop
    GTP Level Member TyroElite's Avatar
    Williamsport, PA
    You still have these pics? I don't see them in the post you started about showing the audio.
    Edit: Nevermind... I found them. I've always heard it was best to keep the ground under 8 to 12 inches... what would you say is max length?
    Also, what do you use to make your raised lettering? I may enlist you for a little project I've got going for my 05
  3. #23 Re: Rap Pop
    GTX Level Member MTXGTP's Avatar
    wamego,KS
    i was told the max length was like 18 inches.
    Justin Young, Kansas
    1999 silver GTP DHP pcm,3" Cattless hogan DP,Front PLOG,3.4 pulley, ported TB, ported LIM, ported supercharger housing.porting done by GBP
    coming soon: LS6 springs ,1.9rr
  4. #24 Re: Rap Pop
    alhambra, Il
    yeah 20 is the most I have ever personally gone, and I really didn't want to do that much but had to, it did not cause any problems. As long as it is a good ground it ill be fine that long, But I would suggest around 10-12" for length on ground, that way you can move it around if you get some noise and troubleshoot it a lil' easier. Mine is a little long, I just used the ground wire out of a capacitor kit and they only give you 20" in that kit and I trimmed it so prolly 14" or so.
    Steven Oliver
  5. #25 Re: Rap Pop
    alhambra, Il
    The raised lettering is easy, I am going to post a how to real soon. So I will let you know when I get that posted up. It is so easy, once you see how to do it, you will be like wth? haha.
    Steven Oliver
pop, rap
