Hi all i am hooking up a after market head unit in my 2004 grand prix with monsoon system.
i don't care if i lose RAP
i don't care much for the chime
i don't have onstar
i also know about the date will be lost on the DIC also
i will disconnect the monsoon system and run new speaker wire,constant 12+/ground and accessory wire.
The question is can/could i use a mini fuse tap on the power sun roof fuse in the fuse panel to get the switched 12+ accessory power that the radio needs to cut on and off.(the fuse is rated @ 20 amps)if you want to know.
o and yes i will replace the factory speakers
