Thread: Rear Speaker Amp
Results 1 to 20 of 27
  1. #1 Rear Speaker Amp
    Donating Users zildjian102's Avatar
    Wilkes Barre, PA
    Okay i have the 8 speaker premium sound system. its time to get rid of the stock amp and stock 6x9's because they distort with even the slightest amount of bass. the speakers arent blown.. they just suck lol. The rear 6x9's are powered by a low frequency amp under the dash.. I want to get aftermarket 6x9's. How can i go about bypassing this amplifier?
    2002 Grand Prix GT- top swap soon
    1997 Pontiac Grand Prix GTP-project/parts
    3.4 pulley, intense tune, SD headers, intake, 180 tstat, al104's
  2. #2 Re: Rear Speaker Amp
    GT Level Member putskijr's Avatar
    Waterloo, Iowa
    run new wires haha, someone prob knows more about the stock systems on these cars then me, i just put subs in
    180* tstat, homemade FWI, autolite 605's, tuned by FoSho99, clear corners, 6000k hids, painted interior, and sum more
  3. #3 Re: Rear Speaker Amp
    Wilkes Barre, PA
    yea thats what i figured.. my cousins monsoon system in his grand am has soooooooooooo much more bass for just 6x9's in the back
  4. #4 Re: Rear Speaker Amp
    6x9's are a waste of time.
    take them out, leave the hole open and install some sort of sub in the trunk.
    If you're getting rid of everything then you'll need a new head unit, amp for the sub and new speakers for up front.
    Get 6.5 component speakers and put the tweets in your stock tweeter location.
    You'll also need an amp wiring kit for the sub amp. single run of 4 gauge should be fine.
    Any halfway decent 12 in a sealed box should do quite well.
    If you want a GOOD 12 I'd reccommend the TC Sounds LMS-R 12" from here:
    TC Sounds LMS-R 12" DVC Subwoofer | Parts-Express.com
    Or if you want to cheap out this one:
    TC Sounds Epic 12" DVC Subwoofer | Parts-Express.com
    Or this:
    DIYCable.com : Intro » Home » Exodus Subwoofers »
    The last one is a balance between the two.
    Less bling but still should work well.
  5. #5 Re: Rear Speaker Amp
    Wilkes Barre, PA
    Thanks matt!! I actually already have an aftermarket head unit and my car is already wired for subs haha so im set. AND i work at best buy and we get huge discounts in car audio
  6. #6 Re: Rear Speaker Amp
    lettuce know what stuff you are considering buying before you buy it.
    Just so we can double check to make sure you're getting the best bang for your buck.
  7. #7 Re: Rear Speaker Amp
    Wilkes Barre, PA
    okay im working on tuesday so im gonna check and see what we have there and see how good my discount is.. i got infinity 6x9's for my cousins car for 70 bucks and they are normally 140
  8. #8 Re: Rear Speaker Amp
    true.
    cost + 10% right?
  9. #9 Re: Rear Speaker Amp
    Wilkes Barre, PA
    cost + 5%
  10. #10 Re: Rear Speaker Amp
    The LED guy.... csssaint12's Avatar
    Nov 2009
    Duluth, Minnesota, United States
    Ok, well I have put in quite a bit of sound systems into peoples cars and you don't necessarily need a new head up and if you want to save some money you can just go to your local Home Depot and get your wiring from there because they sell wire a hell of a lot cheaper than actual wiring kits. I know a lot of people like to get a new head unit when they put subs in a car cause its easier for wiring with an amp, but it is also nice to put your subs on a switch so you can turn them on and off when you please.
  11. #11 Re: Rear Speaker Amp
    Why would you want to switch on and off part of the sound spectrum? If its setup properly you dont need to do that.
    Wiring kit is $50-60 for one pair of RCA's, amp power, ground, remote wire, fuse holder with fuse.
    You can't get all of that for that price shopping separately.
  12. #12 Re: Rear Speaker Amp
    Nov 2009
    switching it on and off is nice when going through a school zone or a hospital zone or when the police pull up next to you at a stop light. and you can easily buy that for less than $60 bucks because I have done it under that.
  13. #13 Re: Rear Speaker Amp
    Turn the volume down? Its pretty easy to do.
    Not here you can't.
  14. #14 Re: Rear Speaker Amp
    Nov 2009
    All the wiring for it costed us less than $20 bucks. Plus not all songs are made to go BOOM BOOM so its nice to turn it off for those songs
  15. #15 Re: Rear Speaker Amp
    You must have no idea how to set up a subwoofer then.
    You're telling me you can purchase 17 feet of 4 gauge wire for less than $20?
    Copper is expensive...
  16. #16 Re: Rear Speaker Amp
    Nov 2009
    You got it I have no idea how to setup a subwoofer at all (Dad is an electrician). Copper is not that expensive. We paid about 53 cents or so a foot at home depot.
  17. #17 Re: Rear Speaker Amp
    I dont mean electrically, i mean setting it up with the crossover, and level.
    And that was 4 gauge?
  18. #18 Re: Rear Speaker Amp
    Nov 2009
    Ya it was right around there. Cause anything over 4 gauge with his amp was just overkill
  19. #19 Re: Rear Speaker Amp
    Feb 2009
    Virginia
    I believe the wiring could be found cheaper. Where you might be losing out is whether or not it's plated to resist corrosion(some companies just plate nickel with copper to be cheap), decent insulation, and flexibility(strand count).
    If you don't care about any of that then you can definitely get some cheap wire. welding cable comes to mind even.
    11 is louder than 10!
  20. #20 Re: Rear Speaker Amp
    GT Level Member chamilton89's Avatar
    Columbus, Ohio, United States
    All this wiring stuff aside (and for the record, I would never get power wire from home depot for many reasons that have already been stated)
    Did u figure out what you want to get speaker wise! I know matt suggested a good system and I know you mentioned infinity. I happen to love infinity and ive always used it. Let us know what you decided!
    Infinity all around.
  1. Rear speaker issues.
    By ReaperRob in forum Audio, Security & Visual Electronics
    Last Post: 11-14-2010, 10:01 PM
  2. Rear speaker removal for a 2008.
    By joeltonya in forum Introductions/Noob Questions
    Last Post: 06-15-2010, 10:14 PM
  3. Rear Deck Speaker Grilles
    By SlowNA06 in forum Audio, Security & Visual Electronics
    Last Post: 05-25-2010, 12:18 PM
  4. rear speaker covers
    By a98gtp4u in forum Audio, Security & Visual Electronics
    Last Post: 11-15-2009, 08:50 PM
  5. 08 rear speaker removal
    By Back in Black in forum Audio, Security & Visual Electronics
    Last Post: 04-01-2009, 07:48 AM
