Thread: Strange electrical problem
Results 1 to 2 of 2
  1. #1 Strange electrical problem
    SE Level Member techweenie's Avatar
    Nov 2009
    Grand Blanc, MI
    Recently my 02 GTP has developed an issue where the DIC, a/c, headlights, and heated seat don't work after starting the car. Sometimes it will all kick on after a minute or two, or it might take half an hour, or just not come on at all. When it does come on, I can hear what sounds like a relay clicking, but I don't know where to look for it. The radio, instrument panel, and HUD are not affected by whatever is causing this. The buttons on the DIC still work, but you can't see anything you change. Does this sound like an ignition switch problem? Its starting to get cold around here and I want to make sure my butt stays warm!
  2. #2 Re: Strange electrical problem
    Nov 2009
    Grand Blanc, MI
    The problem was the ignition switch. I replaced the blower motor resistor first because it was cheaper, but that didn't make a difference. The old one was not OEM, but it looked worse for wear. I wish someone would have given me a hint at what to replace because searches came up empty until I ran across the same problem searching for something entirely unrelated.
  1. strange problem
    By LSXHP in forum General Tech Discussion
    Last Post: 01-15-2011, 01:35 AM
  2. very strange problem.
    By maniakmyke in forum General Tech Discussion
    Last Post: 03-04-2010, 04:45 AM
  3. Strange Trans. problem...help!
    By lastonemade02 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-20-2009, 08:07 AM
  4. Strange interior electrical/light problem
    By frozenlead in forum Audio, Security & Visual Electronics
    Last Post: 08-13-2009, 01:04 AM
  5. Strange car problem, but not as bad as I initially thought
    By Warhellride in forum Off Topic Discussion
    Last Post: 02-04-2009, 09:40 PM
