Thread: power wire question?
Results 1 to 17 of 17
  1. #1 power wire question?
    Feb 2010
    middle o nowhere,PA
    tmrw im putting the subs i had in my suv in my car..now i got a few questions:
    -I will be using the 0 gauge power wire that i had run in my bravada,Will i have to make a hole in the fire wall or is there already an existing hole that i can run it through?
    -Also will the stock alt and a stock size battery support a 1400watt amp and if i feel adventurous a 4ch 400watt amp for my interiors ?
    -can i just swap out the stock front mid/tweeters with some i have and just hook em to the stock wires?
  2. #2 Re: power wire question?
    GTX Level Member kjohnson's Avatar
    Nov 2008
    Harlan, IA and University of Northern Iowa
    Quote Originally Posted by Dragonblaze View Post
    -I will be using the 0 gauge power wire that i had run in my bravada,Will i have to make a hole in the fire wall or is there already an existing hole that i can run it through? there is a firewall grommet you should be able to run it though. it is going to be a ***** but I ran 2 gauge wire through it after some work.
    -Also will the stock alt and a stock size battery support a 1400watt amp and if i feel adventurous a 4ch 400watt amp for my interiors ? Im currently running a 1200 watt sub and something like a 200 watt amp for my 6x9's and have absolutly no problems
    http://www.grandprixforums.net/image...or/menupop.gif
    if you want to run thos off of the deck yes. that is what I am doing. I left the stock speakers in the frount and ran thos with the deck and then the 6x9's in the back are a seperate amp like I said. ull be good to go. I really like that set up its a little hard to get set just how you want it since your basically dealing with 3 amps but it works great once you get it set.
    silver 2003 Grand Prix GT List is on it's way to be updated
  3. #3 Re: power wire question?
    Feb 2010
    middle o nowhere,PA
    Quote Originally Posted by kjohnson View Post
    iiet awsome,this is how i had my old cav Z24 set up and it sounded great..so what i was maybe gonna do here,either that or just leave the 2nd amp out till i can amp all 4 speakers at once.
  4. #4 Re: power wire question?
    Willoughby, Ohio
    run the power wire on the passenger side like kjohnson said and the RCAs and remote on the drivers, GP alternators can take a beating so you should be fine for a while
  5. #5 Re: power wire question?
    Feb 2010
    middle o nowhere,PA
    Quote Originally Posted by CTKGP09 View Post
    this is how i ran them..seemed like the easiest way and looks like nothin changed in the interior..clean install.
    Now i do have a prob ..i got it all installed and damn it sounds good but the damn amp stays on even with the ignition off and remote wire removed.im stumped what the hell would cause this??
  6. #6 Re: power wire question?
    swift current,sask.
    What do you have it wired into?
  7. #7 Re: power wire question?
    Feb 2010
    middle o nowhere,PA
    Quote Originally Posted by whiney View Post
    what the remote wire?..its hooked to the remote wire from the HU wiring harness
    and the power wire is run from the batt to the amp
  8. #8 Re: power wire question?
    Nov 2008
    make damn good and sure that you dont have any 12volt +(from the battery) touching the remote turn on wires mounting bracket. mine are right next to each other so that could easily be a problem for me.
  9. #9 Re: power wire question?
    swift current,sask.
    Well, then you have power backfeeding from somewhere or your deck is screwed.
  10. #10 Re: power wire question?
    Feb 2010
    middle o nowhere,PA
    -UPDATE-
    my amp **** the bed..i hooked up a crunch 600watt 2ch i have and it worx exactly as it should..though the bass i get is half of what my 1400 put out ..but great ti have those low bass notes again..now to search for a decent 1200-2000 watt amp.
  11. #11 Re: power wire question?
    Feb 2010
    middle o nowhere,PA
    see above post but thanx for the input guys
  12. #12 Re: power wire question?
    swift current,sask.
    Go audioque, that will give you the actual 1200 or 2200 that you want...
  13. #13 Re: power wire question?
    That Loud Guy 1LoudGrandPrix's Avatar
    Cedar Rapids, IA
    or sundown they do rated @12 volt at less lol
    98 Camaro SS 46k LS1, T56, All Stock. 00 GMC Sierra 2wd ECSB 106k Lm7, 3.73s tow needs lowered..
    01 Grand Prix GTP "201k" ~111k on motor, ~46k on trans, headers, 3.4 and a tune to come.
    01 Grand Prix GT 168k: Mods: Tune by TheOtherNick. Stereo: 320A alt,4 runs 0/1, XS D3400 front, 1 JYP 80ah Lithium rear, 2 Twisted Sounds 3500s, 2 Sundown Audio NightShade v.3 7 National Records..
  14. #14 Re: power wire question?
    Feb 2010
    middle o nowhere,PA
    whats the avg price in those? i dont have all the $ ever to buy a new amp.
    Quote Originally Posted by TurboTrav View Post
    read above statement and respond please kind sir
  15. #15 Re: power wire question?
    swift current,sask.
    Well, the 1200d is $249 and the 2200d is $389. Both brand new right from audioque.
    The sundowns are wicked amps, little pricey... Their site says $799 msrp on it, but i'm sure you could get a decent deal on them used maybe like $400-550 ish.
  16. #16 Re: power wire question?
    Cedar Rapids, IA
    i got 2 reps in town i don't like buying alot of stuff online
  17. #17 Re: power wire question?
    swift current,sask.
    Hah, I wish... We got wal-mart and a place that deals mtx and kenwood. Lol most of my stuff is bought online or in a bigger city.
  1. Power wire amp to battery
    By yeacashgpgt2002 in forum Audio, Security & Visual Electronics
    Last Post: 09-09-2010, 11:45 AM
  2. Amp power wire help!!!!!
    By Goldoni in forum Audio, Security & Visual Electronics
    Last Post: 05-07-2010, 08:00 AM
  3. new power wire
    By offroadfury6 in forum Audio, Security & Visual Electronics
    Last Post: 12-23-2009, 03:35 AM
  4. Where to run power wire through firewall
    By Bueller in forum Audio, Security & Visual Electronics
    Last Post: 12-05-2009, 11:59 PM
  5. Where to run power wire?
    By 97gp97 in forum Audio, Security & Visual Electronics
    Last Post: 09-25-2008, 02:21 PM
