I got a new key fob from the dealer and they wanted a $100 to program it. Ive found stuff on the web but it didnt work, or im doing it wrong.
pull the MALL programm fuse
close all doors
insert key, turn to ACC then OFF then back to ACC within 1 sec.
open and close a door, a chime should be heard
press and hold the the LOCK and UNLOCK bottuns for 14 seconds.
remove key from ignition
re-install MALL fuse and your done.
what happens if you have a a/m radio and you cant hear chimes how do you know then?
Where is the MALL fuse under the glove box or in the engine fuse box?
Thanks for the info im gonna try it in the morning
didnt work for me either.
More detailed, so try it again
Remove key from from ignition
remove the BCM PROGRAM, from the glove box fuse box, if no BCM fuse is found remove the MALL PROGRAM fuse
close all doors
close the lift gate
insert key into ignition, and turn it to the ACC ( one click towards you in the car)
leave key in for 5 then do next step
turn key to off and back to acc with in one second
open a door and close it, A chime SHOULD be heard when the system enters program mode
press and hold the LOCK and UNLOCK for 14 seconds, after seconds a chime may be heard that will confirm program
remove key
install FUSE
Does this procedure work for an 08 grand prix?
No this process will not work on 2004 and up Grand Prix. That will require a Tech 2 or other scanner to pair the key fob. I did have a Dorman part that would perform this task along with the key fob. I may as well sell the part as it can do 4 programming sessions and I have a virtual Tech 2 now.
