Thread: Brightest bulbs for headlight replace?
Results 1 to 10 of 10
  1. #1 Brightest bulbs for headlight replace?
    Chesaeake VA
    I replaced my headlight bulbs on my 98 GP GT a couple years ago but they still seem dim. What is the BRIGHTEST bulb to replace the one there now? I do not want to do any electrical mods, just find the brightest bulb to change myself - thanks!
  2. #2 Re: Brightest bulbs for headlight replace?
    Pennsylvania
    Sylvania Silverstar Ultra
  3. #3 Re: Brightest bulbs for headlight replace?
    Norristown, PA
    LED's...I kid.
    Get HID's, there plug and play.
  4. #4 Re: Brightest bulbs for headlight replace?
    SE Level Member Mje00GPGt's Avatar
    Anoka, MN
    Or there is a brand called Halo that makes bulbs cheaper than the Silverstars and you get a color selection. They sell em on ebay i used them in my old car and they were pretty bright. Im also looking at new headlight bulbs as well
  5. #5 Re: Brightest bulbs for headlight replace?
    Norristown, PA
    Quote Originally Posted by Mje00GPGt View Post
    There ****ty bulbs. I use them for my fogs, only for color. I get no output from them.
  6. #6 Re: Brightest bulbs for headlight replace?
    Jul 2010
    Outside ATL
    you are never going to be happy with the output in the stock headlight housings. The only alternative is doing a retro fit into your stock housing. You can put all the bulbs you want that claim to be the brightest and such but its not going to change the fact that the reflector sucks. Even plug and play hid's suck for our cars. Dont let anyone fool you on this, ive been doing this for years. I did a retro fit into my housings with rx-330 projectors/300zx clear lens swap it is awesome. Check out hidplanet.com and they will school your woes for sure.
  7. #7 Re: Brightest bulbs for headlight replace?
    Chesaeake VA
    The HID install looks easy on the demo for 9007-2 conversion kit. Think I will give that a try. Opinions? Seems popular on this forum. Standard kit.
  8. #8 Re: Brightest bulbs for headlight replace?
    Dec 2008
    Lawndale, CA
    HIDs will be the brightest. If you want to take advantage of light output then retroffited projectors or even the spyder auto projectors with HIDs would be a nice upgrade. If you want to keep halogens then any bulb with a blue coating will limit light output. You will need to use the one's with a clear lens on them like the GE nighthawks, philips xtreme etc. You could pair them with a harness to get more voltage to the bulbs from the battery. You could also try higher wattage halogen bulbs with a relay harness.
  9. #9 Re: Brightest bulbs for headlight replace?
    Chesaeake VA
    I went ahead and bought the kit shown below from VVWD as per the recommendations on several threads - thanks I'll let you know how the install goes - if I can do it, anyone can!
    1 x Standard 9007-3 Bi-Xenon HID Kit (VVME-HKBIX-973) = $58.99
    Color Temp. 6000K
  10. #10 Re: Brightest bulbs for headlight replace?
    GTP Level Member SnowDrift's Avatar
    Apr 2009
    Central Ohio map dot.
    So, this kit will give you hi and lo beams, still and will be brighter than the Sylvania Ultra? I'm also interested in this since the stock output seems poor to me, compared to the mini sealed beams of our '93 GP. Please do post back and let us know about installation and how they compare.
  1. Replace DIC bulbs??
    By SDGTP99 in forum General Tech Discussion
    Last Post: 05-12-2013, 10:14 PM
  2. Headlight Bulbs
    By MrPhotographer06 in forum Visual/Body Modifications
    Last Post: 05-18-2010, 09:38 PM
  3. Headlight bulbs? Whats the best/ most bright?
    By 87GN97GTP in forum Visual/Body Modifications
    Last Post: 01-21-2010, 07:32 PM
  4. Does anyone know the Wattage draw of the Stock headlight Bulbs?
    By Blacknight02GT in forum Off Topic Discussion
    Last Post: 06-26-2009, 11:33 AM
